First of all, I am undecided where the proper location is for my question: Project Guidance or Programming Questions because I am not really sure what is wrong... ![]()
Overview: I bought the above Fanatec CSR pedals a long time ago. They had a RJ-12 to PS/2 connector to connect directly to the Fanatec racing wheel. Since I am planning to make a DIY racing wheel, I want to connect the pedals directly to the Arduino Leonardo.
Details: I figured out the pedals pinout via this ISRTV forum. I posted my findings above. I proceeded to cut the PS/2 connector end and splice the wires. I connected the wires to the Arduino according to my findings as pictured below.
Testing: Before starting the coding process, I tested the output of the Gas, Brake, and Clutch potentiometers with the following code and got the following readings: Gas(857 - 214), Brake(1007 - 275), and Clutch(760 - 705).
#include <XInput.h>
#include <Wire.h>
int gas = analogRead(A0);
//Serial.println(gas); //857 - 214
int brake = analogRead(A1);
//Serial.println(brake); //1007 - 275
int clutch = analogRead(A2);
//Serial.println(clutch); //760 - 705
Xinput Code: After finding the readings of the potentiometers, I proceeded to write the code for the Arduino controller as follows.
#include <XInput.h>
#include <Wire.h>
XInput.begin();
XInput.setRange(JOY_RIGHT, 275, 1007);
XInput.setRange(JOY_LEFT, 705, 760);
XInput.setRange(TRIGGER_RIGHT, 214, 857);
XInput.setTrigger(TRIGGER_RIGHT, gas);
XInput.setJoystickY(JOY_RIGHT, brake);
XInput.setJoystickX(JOY_LEFT, clutch);
Problem: In Windows 10, under "Devices and Printers", my controller shows up as an Xbox 360 controller thanks to the ArduinoXInput library, which is good. Under "Game Controller" properties, I see Z-Axis, X-Rotation, Y-Rotation, X-Axis, Y-Axis, just like a normal Xbox 360 controller, which is also good. When I press either the Gas, Brake, or Clutch, the output of the Gas, Brake, and Clutch shows up correctly in the Game Controller properties. ![]()
However, the problem is that in Euro Truck Simulator 2, for example, when I press the Gas pedal to the max, the truck accelerates very slowly, as if I am not pressing the Gas pedal to the max... :![]()
Question: Did I code this incorrectly? Why is the game not detecting the whole range of the pedals? ![]()
Bonus Question: I would prefer the Clutch to be on the right joystick X rotation. How would I go about programming this?
