I am encountering Arduino memory issues with the following project.
I am using using individually addressable LED rings for my project. Each ring has 16 LEDs. I have 63 rings (1008 leds) connected in line for my setup. I already figured out the needed power so no problems there, but there is another problem with Arduino memory. When a button is pressed, each ring (16 LED) light up, and then once you press the button again, another one lights up and so on.....
I added candle effect to each ring (16 leds), and it works pretty well if only 4-5 rings are lit, but the more rings I light, the slower the effect becomes. After turning on 15 or more rings, even the button stops responding and the entire system is unusable. Is there another way to program this to avoid this issue? When applying the candle effect, you have to constantly write to each LED in each ring to achieve the effect, so i am not sure if there is a way to somehow group it, so it is not eating up all the memory?
#include <LiquidCrystal.h>
#include <FastLED.h>
// Define LED ring parameters
#define NUM_LEDS 1008
#define DATA_PIN 9
// Define the array of LEDs
CRGB leds[NUM_LEDS];
// Initialize the LCD with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 2, 3, 4, 5); // RS, E, D4, D5, D6, D7 for communication
const int buttonPin = 8; // Pin connected to the color change button
const int randomLedButtonPin = 10; // Pin connected to the random LED button
const int potentiometerPin = A0; // Pin connected to the potentiometer for changing how long lights stay on
int buttonState = 0;
int lastButtonState = 0;
int randomLedButtonState = 0;
int lastRandomLedButtonState = 0;
int colorIndex = 0;
const char* colors[] = {"Red", "Green", "Purple", "Yellow", "White"};
const int numColors = sizeof(colors) / sizeof(colors[0]);
CRGB colorValues[] = {
CRGB::Red,
CRGB::Green,
CRGB(128, 0, 128), // Purple
CRGB::Yellow,
CRGB::White
unsigned long previousMillis = 0;
unsigned long interval = 5000; // Default interval (5 seconds)
unsigned long ledOnTime[NUM_LEDS] = {0};
// Noise variables for candle effect
uint16_t x = 0; // Used for candle effect noise generation
uint16_t y = 0;
uint16_t z = 0;
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Color: ");
lcd.print(colors[colorIndex]);
// Initialize the button pins as input
pinMode(buttonPin, INPUT);
pinMode(randomLedButtonPin, INPUT);
// Initialize the LED lights
FastLED.addLeds<WS2812, DATA_PIN, GRB>(leds, NUM_LEDS);
FastLED.setBrightness(150);
// Set initial color
setStripColor(CRGB::Black); // Turn off all LEDs initially
// Initialize serial communication for debugging
// Read the state of the buttons
buttonState = digitalRead(buttonPin);
randomLedButtonState = digitalRead(randomLedButtonPin);
// Check if the color change button was pressed
if (buttonState != lastButtonState) {
if (buttonState == HIGH) { // HIGH indicates the button is pressed
// Change the color index
colorIndex = (colorIndex + 1) % numColors;
// Clear the entire line on the LCD before printing the new color
lcd.setCursor(7, 0); // Set cursor to the first character of the color display
lcd.print(" "); // Clear the line by printing spaces
// Update the LCD display with the new color
lcd.setCursor(7, 0); // Set cursor back to the first character of the color display
lcd.print(colors[colorIndex]); // Print the new color
// Update the LED lights
setStripColor(colorValues[colorIndex]);
// Debounce delay
delay(50);
// Light up all LEDs in one ring if the random LED button is pressed
if (randomLedButtonState != lastRandomLedButtonState && randomLedButtonState == HIGH) {
// Randomly select a ring (0 for first ring, 1 for second ring)
int selectedRing = random(NUM_LEDS/16);
// Calculate the start and end indices for the selected ring
int startIdx = selectedRing * 16;
int endIdx = startIdx + 16;
// Check if any LED in the selected ring is already on
bool ringIsOn = false;
for (int i = startIdx; i < endIdx; i++) {
if (leds[i] != CRGB::Black) {
ringIsOn = true;
// If the selected ring is already on, choose the other ring
if (ringIsOn) {
selectedRing = (selectedRing == 0) ? 1 : 0;
// Blink all LEDs in the selected ring three times with blue
for (int i = 0; i < 3; i++) {
for (int j = startIdx; j < endIdx; j++) {
leds[j] = CRGB::Blue;
FastLED.show();
leds[j] = CRGB::Black;
FastLED.show();
// Light up all LEDs in the selected ring with the main color
leds[j] = colorValues[colorIndex];
ledOnTime[j] = millis(); // Save the current time for each LED
FastLED.show();
// Apply candle effect to each ring
for (int ring = 0; ring < NUM_LEDS / 16; ring++) {
int startIdx = ring * 16;
applyCandleEffect(startIdx, endIdx);
// Check if the interval has elapsed since the last LED lighting
for (int i = 0; i < NUM_LEDS; i++) {
if (currentMillis - ledOnTime[i] >= interval) {
leds[i] = CRGB::Black;
FastLED.show();
// Save the current state as the last state for the next loop
lastButtonState = buttonState;
lastRandomLedButtonState = randomLedButtonState;
// Read potentiometer value and map it to the desired intervals
int potValue = analogRead(potentiometerPin);
interval = map(potValue, 250, 950, 5000, 15000); // Map potentiometer value to interval range (5-15 seconds)
// Debug: Print potentiometer value to serial monitor
Serial.println(potValue);
// Update interval on LCD
lcd.setCursor(0, 1);
lcd.print("Interval: ");
lcd.print(interval / 1000); // Display interval in seconds
lcd.print("s "); // Clear any extra characters from previous value
void setStripColor(CRGB color) {
leds[i] = color;
FastLED.show();
void applyCandleEffect(int startIdx, int endIdx) {
uint8_t flicker = random8(128, 255);
leds[i] = colorValues[colorIndex];
leds[i].fadeLightBy(flicker);
x += 1;
y += 1;
z += 1;
FastLED.show();
The amount of time each candle stays on is also not seconds but days. This code above was just for testing if the timer works. So the values for time range from min 1day to max 5 days.
This is the final code that i have with the candle effect completely removed because it is causing problem. If one of your guys can help with adding something that would work. Please notice that the system can have one of 4 color set (Red, Green, Purple, White), so the candle effect should just be there to dim/blink the currently set color, not change it to different color.
Code below:
#include <Wire.h>
#include <hd44780.h> // Main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
#define DATA_PIN 9
#define NUM_RINGS (NUM_LEDS / 16) // Number of rings
// Initialize the LCD with the I2C address 0x27 (common for most I2C LCDs)
hd44780_I2Cexp lcd; // Declare lcd object
const int durationButtonPin = 11; // Pin connected to the duration change button
int buttonState = HIGH; // Default to HIGH (input_pullup)
int lastButtonState = HIGH;
int randomLedButtonState = HIGH; // Default to HIGH (input_pullup)
int lastRandomLedButtonState = HIGH;
int durationButtonState = HIGH; // Default to HIGH (input_pullup)
int lastDurationButtonState = HIGH;
int colorIndex = 0;
const char* colors[] = {"RED", "GREEN", "PURPLE", "WHITE"};
CRGB::Red,
CRGB::Green,
CRGB(255, 0, 255), // Darker Purple
CRGB::White
unsigned long interval = 86400000; // Default interval (1 day)
// Boolean array to keep track of whether each ring is lit
bool ringsLit[NUM_RINGS] = {false};
// Array to store ring indices and current index for picking
int ringIndices[NUM_RINGS];
int currentRingIndex = 0;
// Duration options in milliseconds
unsigned long durationOptions[] = {86400000, 172800000, 259200000, 345600000, 432000000}; // 1, 2, 3, 4, 5 days
int durationIndex = 0; // Index for the current duration option
// Debounce variables
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50; // Debounce time in milliseconds
unsigned long lastRandomLedDebounceTime = 0;
unsigned long lastDurationDebounceTime = 0;
lcd.begin(16, 2); // Initialize with the correct number of columns and rows
lcd.setBacklight(1);
// Initialize the button pins as input pullups
pinMode(buttonPin, INPUT_PULLUP);
pinMode(randomLedButtonPin, INPUT_PULLUP);
pinMode(durationButtonPin, INPUT_PULLUP);
FastLED.setBrightness(75);
// Initialize ring indices
for (int i = 0; i < NUM_RINGS; i++) {
ringIndices[i] = i;
shuffleRingIndices(); // Shuffle the ring indices
// Display initial interval on LCD
lcd.print(durationOptions[durationIndex] / 86400000); // Display interval in days
lcd.print(" DAYS");
int reading = digitalRead(buttonPin);
int randomLedReading = digitalRead(randomLedButtonPin);
int durationReading = digitalRead(durationButtonPin);
// Debounce the color change button
if (reading != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState == LOW) { // Button is pressed
// Debounce the random LED button
if (randomLedReading != lastRandomLedButtonState) {
lastRandomLedDebounceTime = millis();
if ((millis() - lastRandomLedDebounceTime) > debounceDelay) {
if (randomLedReading != randomLedButtonState) {
randomLedButtonState = randomLedReading;
if (randomLedButtonState == LOW) { // Button is pressed
bool allRingsLit = true;
// Check if any ring is not lit
if (!ringsLit[i]) {
allRingsLit = false;
// Only proceed if not all rings are lit
if (!allRingsLit) {
// Attempt to find an unlit ring by using the shuffled indices
int selectedRing = ringIndices[currentRingIndex];
currentRingIndex = (currentRingIndex + 1) % NUM_RINGS;
// If the ring is not lit, proceed to light it
if (!ringsLit[selectedRing]) {
FastLED.show();
FastLED.show();
FastLED.show();
// Mark the ring as lit
ringsLit[selectedRing] = true;
// Debounce the duration button
if (durationReading != lastDurationButtonState) {
lastDurationDebounceTime = millis();
if ((millis() - lastDurationDebounceTime) > debounceDelay) {
if (durationReading != durationButtonState) {
durationButtonState = durationReading;
if (durationButtonState == LOW) { // Button is pressed
// Change the duration index
durationIndex = (durationIndex + 1) % 5;
interval = durationOptions[durationIndex];
// Update the interval display on the LCD
lcd.print(" DAYS");
if (leds[i] != CRGB::Black && currentMillis - ledOnTime[i] >= interval) {
int ringIndex = i / 16;
ringsLit[ringIndex] = false; // Mark the ring as not lit
FastLED.show();
lastButtonState = reading;
lastRandomLedButtonState = randomLedReading;
lastDurationButtonState = durationReading;
leds[i] = color;
FastLED.show();
void shuffleRingIndices() {
for (int i = NUM_RINGS - 1; i > 0; i--) {
int j = random(0, i + 1);
int temp = ringIndices[i];
ringIndices[i] = ringIndices[j];
ringIndices[j] = temp;
FastLED.show() for your leds lasts about 30 ms. You do it every time you call the applyCandleEffect() function. So applying a candle effect to all 63 rings need about 2 seconds for EACH STEP of changing.
Try do not apply FastLED.show() after changing each rings, do it once after all rings changed.
Really!!! I wasted your time by asking for help. I posted the second final code so you can see what it is trying to do and i stated
"This is the final code that i have with the candle effect completely removed because it is causing problem. If one of your guys can help with adding something that would work."
If you think i wasted your time maybe you should just not comment at all instead to giving me"(expletive deleted) comments"
You asked for help with the candle effect being too slow. And when I suggested to you how to fix this problem, you simply threw the effect out of the code, thereby devaluing my efforts.
And now you expect me to waste time on your new code? - no thanks, try it yourself this time.
I'm confused, resting state but also by this comment
I thought there were 16 rings.
Can you remove the candle effect a bit less aggressively, that is to say just take the original code and just // comment out the call to applyCandleEffect()?
When you say the button(s) stop working, is that literal or are you saying they are sluggish, unresponsive?
You've got the serial monitor, crank up the baud rate to something your grandfather could only have dreamed of, like 115200.
Then out some printing in there to see, for example, tunings like whether the code is even reading the buttons, and if so how frequently.
I haven't begun to look because I see some eyes are already on this deeper than I can get just now, but if it literally goes south, you may somewhere be writing off the end of the pixel buffer array, which would mean your sketch could do almost anything and be be blameless for doing.
I also haven't looked at how hard it wou,d be, but you could try 16 rings of, say, 5 pixels, no matter how that looked, and see if you have the same issues.
This looks weird, talk about it to me. I'm a bit baked, TBH.
This looks like 63 rings of 16 numbered 0 to 62, amIRight?
This applies even without the "candle effect."
Update ALL of the ring display values, and then do ONE "show" per loop(), and you might have enough FPS to add the candle back in.
In theory, 30ms per update is better than 30 frames/sec, which should be plenty to be pretty smooth.
The pot goes from 0 to 1023. map() will extrapolate.
so you will get (too lazy to do the maths) a wider range than the comment suggests.
I am agreeing with @b707 and @westfw, this really calls for a once-per-loop output to all LEDs.
The "busy, select another" logic does not exist. If N = 0 is busy, 1 is selected. If N != 0 is busy, 0 is selected. Is that what you wanted? I was looking for a "find an free ring", which would be kinda complicated in this sketch right now. I would maintain the rings with some kind of data structure, busy, not, age; you'd save memory becuase all the LEDs in a ring are da same age. Pluis a few details.
