ArduinoISP help
Hello,
I am trying to use the ArduinoISP sketch to upload a custom hex file (burning the bootloader using the IDE works). I am using the Evil Mad Scientist ISP Shield, so I am certain my wiring is correct. My issue is that running the below AVRdude command recognizes and programs my Uno, rather than my bare ATmega328p chip.
avrdude -c arduino -p atmega328p -P /dev/cu.usbmodem14201
Here is the output when I run AVRdude with the programmer set to avrisp, rather than arduino.
$ avrdude -c avrisp -p m328p -P /dev/cu.usbmodem14201 -vvv
avrdude: Version 6.3, compiled on Nov 16 2020 at 16:16:00
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/usr/local/Cellar/avrdude/6.3_1/etc/avrdude.conf"
         User configuration file is "/Users/myname/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem14201
         Using Programmer              : avrisp
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel AVR ISP
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Any assistance figuring this out would be much appreciated.
You need to set the baud rate for avr dude to 19200 in the avrdude command, and you might need to take steps to defeat the auto-reset.
Thank you so much! Using the -b 19200 argument fixed it, and it properly reads the fuses and signature.
