Calling the LowPower.sleep(..) function from the ArduinoLowPower library causes I2S audio playback using the ArduinoSound library to crash.
The sketch below is based on the WavePlayback demo sketch, with a small delay between playbacks. If delay() is used, the sketch works as expected. However, if LowPower.sleep(..) audio playback crashes.
Any ideas or suggestions would be most welcome.
Thank you
This reads a wave file from an SD card and plays it using the I2S interface to
a MAX08357 I2S Amp Breakout board.
Circuit:
* Arduino/Genuino Zero, MKRZero or MKR1000 board
* SD breakout or shield connected
* MAX08357:
* GND connected GND
* VIN connected 5V
* LRC connected to pin 0 (Zero) or pin 3 (MKR1000, MKRZero)
* BCLK connected to pin 1 (Zero) or pin 2 (MKR1000, MKRZero)
* DIN connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero)
created 15 November 2016
by Sandeep Mistry
#include <SD.h>
#include <ArduinoSound.h>
#include <ArduinoLowPower.h>
// filename of wave file to play
const char filename[] = "SONG0.WAV";
// variable representing the Wave File
SDWaveFile waveFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// setup the SD card, depending on your shield of breakout board
// you may need to pass a pin number in begin for SS
Serial.print("Initializing SD card...");
if (!SD.begin()) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// create a SDWaveFile
waveFile = SDWaveFile(filename);
// check if the WaveFile is valid
if (!waveFile) {
Serial.println("wave file is invalid!");
while (1); // do nothing
// print out some info. about the wave file
Serial.print("Bits per sample = ");
Serial.println(waveFile.bitsPerSample());
long channels = waveFile.channels();
Serial.print("Channels = ");
Serial.println(channels);
long sampleRate = waveFile.sampleRate();
Serial.print("Sample rate = ");
Serial.print(sampleRate);
Serial.println(" Hz");
long duration = waveFile.duration();
Serial.print("Duration = ");
Serial.print(duration);
Serial.println(" seconds");
// adjust the playback volume
AudioOutI2S.volume( 50 );
// check if the I2S output can play the wave file
if (!AudioOutI2S.canPlay(waveFile)) {
Serial.println("unable to play wave file using I2S!");
// start playback
Serial.println("starting playback");
AudioOutI2S.play(waveFile);
do {
// wait
while ( AudioOutI2S.isPlaying() );
* Using delay(..) works as expected
* Using LowPower.sleep(..) causes audio playback to stop working
//delay(1000);
LowPower.sleep(1000);
Serial.println("Playing file again ");
do {
// wait
