Artemis module with Qwiic pressure sensor
Hi! I have used my ARTEMIS module before with a micro pressure sensor connected with the qwiic wire. However, now the artemis module is note detecting the sensor when I try to run the system with CollTerm I get the following response:
Artemis OpenLog v1.7
ICM-20948 failed to init.
SD card offline
Datalogging offline
Serial logging offline
IMU offline
Identifying Qwiic Muxes...
Identifying Qwiic Devices...
No Qwiic devices detected
rtcDate,rtcTime,output_Hz,
How can I fix this? I know the sensor is working as it is working with a different board as well as the wire
@santiagomzs
Why did you start a topic in the Uncategorised section of the forum when its title is very plainly
DO NOT CREATE TOPICS IN THIS CATEGORY
Your topic has been moved to the Programming section of the forum
