Artnet broadcast call
I'm running an Arduino Mega with Ethernet Shield, connected to a couple of meters of WS2812b leds (and appropriate power supply). I can control the leds directly in code - using FastLED - but when I try compiling ArtNet it fails at EthernetUDP. I've tried multiple different libraries that contain EthernetUDP, and even Ethernet2 to see if that changes things, but it just won't complete :
arx::artnet::Manager}' has no member named 'setBroadcast'
artnet.setBroadcast(broadcast);
This example will receive multiple universes via Artnet and control a strip of ws2811 leds via
Adafruit's NeoPixel library: https://github.com/adafruit/Adafruit_NeoPixel
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
// Neopixel settings
const int numLeds = 240; // change for your setup
const int channelsPerLed = 3;
const int numberOfChannels = numLeds * channelsPerLed; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = 5;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_GRB + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 1; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// Change ip and mac address for your setup
byte ip[] = {192, 168, 0, 3};
byte mac[] = {0xA4, 0x53, 0x0B, 0xBF, 0x21, 0x14};
byte broadcast[] = {192, 168, 0, 255};
  //Serial.begin(115200);
  artnet.begin(mac, ip);
  leds.begin();
  initTest();
  // this will be called for each packet received
  artnet.setArtDmxCallback(onDmxFrame);
  // we call the read function inside the loop
  artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data, IPAddress remoteIP)
  sendFrame = 1;
  // set brightness of the whole strip
  if (universe == 15)
    leds.setBrightness(data[0]);
    leds.show();
  // Store which universe has got in
  if ((universe - startUniverse) < maxUniverses)
    universesReceived[universe - startUniverse] = 1;
  for (int i = 0 ; i < maxUniverses ; i++)
    if (universesReceived[i] == 0)
      //Serial.println("Broke");
      sendFrame = 0;
  // read universe and put into the right part of the display buffer
  for (int i = 0; i < length / channelsPerLed; i++)
    int led = i + (universe - startUniverse) * (previousDataLength / channelsPerLed);
    if (led < numLeds) {
      if (channelsPerLed == 4)
        leds.setPixelColor(led, data[i * channelsPerLed], data[i * channelsPerLed + 1], data[i * channelsPerLed + 2], data[i * channelsPerLed + 3]);
      if (channelsPerLed == 3)
        leds.setPixelColor(led, data[i * channelsPerLed], data[i * channelsPerLed + 1], data[i * channelsPerLed + 2]);
  previousDataLength = length;
  if (sendFrame)
    leds.show();
    // Reset universeReceived to 0
    memset(universesReceived, 0, maxUniverses);
void initTest()
  for (int i = 0 ; i < numLeds ; i++)
    leds.setPixelColor(i, 127, 0, 0);
  leds.show();
    leds.setPixelColor(i, 0, 127, 0);
  leds.show();
    leds.setPixelColor(i, 0, 0, 127);
  leds.show();
    leds.setPixelColor(i, 0, 0, 0);
  leds.show();
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Where did you get the ArtNet library?
Thanks for asking. I've tried the library version (manage library, search Artnet), natcl's - GitHub - natcl/Artnet: An Art-Net library for Teensy, Arduino and ESP boards - branch, hideakitai's - GitHub - hideakitai/ArtNet: Art-Net Sender/Receiver for Arduino (Ethernet, WiFi) - branch and tobiasebsen's - GitHub - tobiasebsen/ArtNode: Art-Net library for Arduino, Teensy, etc. - branch.
I'm pretty sure I'm lacking an accompanying library or the version I'm using isn't compatible, but it won't upload to my Mega.
Why do you believe the call to setBroadcast is necessary? I assume the library would handle that detail for you.
