AS5600 sensor analog output problem in distance
Assalamualaikum, I'm using AS5600 Magnetic Encoder Sensor for one of my project. When I setup magnet distance 1 mm in between magnet and AS5600, I got both I2C and analog signal smoothly. But when the distance is 3mm or more I got only I2C value correctly and did not get any analog signal. I study the datasheet and I did not found any logical cause.
I'm using 3.3v in whole system, battery powered. And using the module board so that did not add additional capacitor.
I need the analog signal in between 3 to 5 mm distance. Please suggest a guideline to get the data.
Thank you.
I've tried in several distance. Only 1 mm distance provide analog signal. my expecting is to get signal from the sensor from 5 mm distance.
Like this?
Suggest you use a motre powerful magnet.
Yes, I'm using this sensor, but faced problem to get analog voltage when magnet is more than 3mm distance. in this case I2C works fine.
