Atmega2560V, trying to burn bootloaders of MegaCore.
Hello,
I am trying to burn MegaCore bootloaders to it, I have setup my custom PCB with Atmega2560V-8AU and 8Mhz Crystal + Load Caps all assembled on using PCBA process.
I am trying to burn MegaCore bootlaoders to it, I am using Arduino UNO as ISP Programmer. My connections are all correct, It shows different Device Signatures (see below) whenever I hit Burn Bootloaders....
0x0000ff
0x00003f
0x0000ff
0x00ff00
0x001000
0xff0000
0xfc0000
0x00fe00
This is complete output with different Device Signatures
Arduino: 1.8.3 (Windows 10), Board: "ATmega2560, Arduino MEGA pinout, 2.7v, Disabled (default), 8 MHz external"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-avr-100-pin\avr/avrdude.conf -v -patmega2560 -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd6:m -Ulfuse:w:0xf7:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-avr-100-pin\avr/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x00fe00
avrdude: Expected signature for ATmega2560 is 1E 98 01
Double check chip, or use -F to override this check.
avrdude done. Thank you.
option enabled in File -> Preferences.
What should be the problem.??? How to solve this.?
Also posted at:
and:
