I have a problem when loading the bootloader into the Atmega328PB-AN custom chip, I use an arduino nano as a programmer. When I upload the code via Arduino to Atmega328PB-an it works normally, when I connect usb to computer it connects Ch340G to computer. When I upload the bootloader in arduino ide and use MiniCore library it says it will upload but when I try to upload the code to Atmega328PB-an it throws :
avrdude warning: programmer is not responding; try -xstrict and/or vary -xdelay=100
avrdude error: unable to open programmer urclock on port COM9
Core 2.0.11 and optiboot please!
I am new in this, You mean MiniCore version 2.0.11? and what is optiboot?
Using Port : COM5
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328PB
Chip Erase delay : 10500 us
PAGEL : PD7
BS2 : PC2
RESET disposition : possible i/o
RETRY pulse : SCK
Serial program mode : yes
Parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Alias Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
signature 0 0 0 0 no 3 1 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 1 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Please, explain your latest post. Does that mean you were successful?
No, it starts saying:
avrdude error: programmer is not responding
avrdude warning: attempt 1 of 10: not in sync: resp=0x00
Yes! In version core 2.0.11 bootloader is optiboot! Please reprogramm bootloader!
Using Port : COM5
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
avrdude: device signature = 0x1e9516 (probably m328pb)
avrdude: Note: flash memory has been specified, an erase cycle will be performed.
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file C:\Users\tejml\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.2.2/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex for flash
with 484 bytes in 2 sections within [0x7e00, 0x7fff]
using 4 pages and 28 pad bytes
avrdude: writing 484 bytes flash ...
Writing | ################################################## | 100% 0.08s
avrdude: 484 bytes of flash written
avrdude: verifying flash memory against C:\Users\tejml\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.2.2/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex
Reading | ################################################## | 100% 0.00s
avrdude: 484 bytes of flash verified
avrdude: reading input file 0xcf for lock
with 1 byte in 1 section within [0, 0]
avrdude: writing 1 byte lock ...
avrdude: 1 byte of lock written
avrdude: verifying lock memory against 0xcf
avrdude: 1 byte of lock verified
avrdude done. Thank you.
So the problem is in the CH-340 converter
Like in the wiring or in the ch340g itself? Should I try replacing the ch340g?
R6 and R7 1K ohm, I'll try replacing the ch340g and then I'll see and let you know according to what you sent I'm all good. Thank you very much for your help.
I've tried 2 things:
- I connected the arduino to the computer and sent data to it via serial communication ( serial monitor ) , the Rx diode flashed.
- I uploaded the code via Arduino Nano ( ISP ) to output the "hello" from the serial monitor, the Tx diode flashed and it output.
So I don't know where the fault is anymore, I'm wondering if it's a fault with the reset circuit (because some places have RST* over 100nF and some places have DTR* over 100nF) that the ch340g would not reset the Atmega328pb. So it couldn't bootloader there and that's why it says:
