Dear Community,
i have done bootloading process using ATMEL ICE for ATmega328PB successfully. But still getting error while uploading sketch using Arduino IDE.
Sketch uses 594 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa6
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa6
Failed uploading: uploading error: exit status 1
Please help to come out from this error.
Thanks
Which board have you selected in the IDE?
Which bootloader did you use?
If you designed a PCB yourself and are using that, a schematic will help. You can drag and drop an image of it in a reply.
Please enable Show verbose output during upload, perform an upload and post the results here using code tags (the <CODE/> button).
I asked a few questions, answer them all please.
And I asked to post the output using code tags, not a screenshot.
A Nano does not have a 328PB but a 328P or 168P. If you're really using a 328PB, I suggest that you install the MiniCore board package.
Hello sterretje,
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc6
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc6
i use Arduino Uno, ATMEGA 328P
How can i fix this problem.
Thank you!
I'm a little confused. You said that you have a 328PB and the Uno does not have a 328PB but a 328P.
If you indeed have a 328PB, I (again) suggest that you look at the MiniCore board package that I linked earlier because you are using a 328PB. I have no experience with the 328PB or MiniCore; it's still on my to-do list.
Code tags are three back ticks (```) on their own line before and after the block, not three ticks (''') as you used
