hi all,
i just got an issue with my Atmega32A chip , i've tried to set the fuse bits for using an external oscillator ,then the chip doesn't respond.
the setting i think is good .
here is what i set the fue bits to :
for High fuses : 0b11011001
OSD ---> 1
JTAG ---> 1
SPI ---> 0
Watchdog ---> 1
EEPROM ---> 1
bootsize ---> 0
............ ---> 0
boot reset ---> 1
for Low fuses : 0b11110111
CKDIV8 ---> 1
CKOUT ---> 1
SUT1 ---> 1
SUT0 ---> 1
CKSEL3 ---> 0
CKSEL2 ---> 1
CKSEL1 ---> 1
CKSEL0 ---> 1
i also use a 16Mhz external oscillator with 22pf ceramic caps for the external clock signal !
would it be a wrong fuse bit set , or me having a bad clock signal ?
note: i also tried to generate a squared signal of more then 1Mhz in the XTAL1 pin with an arduino board , but the board still doesn't respond .
i keep getting these errors when ever using the avrdude with this chip :
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: error: program enable: target doesn't answer. 1
avrdude.exe: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.avrdude.exe done. Thank you.
any guidance/help would be very apreciated !
best regards,
