I have 2 servos, and put them manually on X position, for example, servo1 = 20º and servo2 = 160º, but when I turn on arduino, setup() function execute attach() servos, then servos put in 90º, why ?
I need don’t move servos when I execute attach in setup(). It's possible?
When you attach a servo the arduino starts sending position information to it. By default, that starting position is 90. You can change that by doing a servo.Write before you do the attach.
However, you can't set the servo to some random manual position and expect that it won't move to its start position when you attach.
The below servo test code has a line where an initial servo attach position can be specified. Your problem is probably that the servos are in a different position when attached in the code. A possible solution would be to not attach the servos until they need to be sent to a specific positioned in the code.
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7, 500, 2500); //the pin for the servo control, and range if desired
Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
readString=""; //empty for next input
Hi, when you say manually, do you mean you physically turn the shaft of the servo?
In my opinion I would NEVER force a servo to any position with power ON or OFF, the servo contains a gearbox and motor, the gearbox is usually, especially on cheap servos, nylon and designed ONLY for torque output.
When you force the servo, the gearbox will TRY to spin the motor at a high speed and you will find you are having to use a lot of torque to do so. If you overload the gearbox with too much torque then the gears will strip or break.
