Hello Everyone,
I am fairly new to Arduino and have been attempting my first project using a sensor and display.
I have a DHT22 sensor that I am trying to use with a SH1106 display. The problem is, the example I found online is written for a SSD1306 dsiplay.
My difficulty is changing the code to allow it to work with a SH1106 rather than the SSD1306.
The code provided is:
#include <Wire.h>
#include "DHT.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define DHTTYPE DHT22
Adafruit_SSD1306 display = Adafruit_SSD1306(128, 64, &Wire, -1);
unsigned long delayTime;
uint8_t DHTPin = 2;
DHT dht(DHTPin, DHTTYPE);
float Temperature;
float Humidity;
float Temp_Fahrenheit;
pinMode(DHTPin, INPUT);
dht.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.display();
delay(100);
display.clearDisplay();
display.display();
display.setTextSize(1.75);
display.setTextColor(WHITE);
void loop(){
Humidity = dht.readHumidity();
// Read temperature as Celsius (the default)
Temperature = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
Temp_Fahrenheit = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(Humidity) || isnan(Temperature) || isnan(Temp_Fahrenheit)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
Serial.print(F("Humidity: "));
Serial.print(Humidity);
Serial.print(F("% Temperature: "));
Serial.print(Temperature);
Serial.print(F("°C "));
Serial.print(Temp_Fahrenheit);
Serial.println(F("°F "));
display.setCursor(0, 0);
display.setTextSize(1);
display.print("Temperature: ");
display.setTextSize(2);
display.setCursor(0, 10);
display.print(Temperature);
display.print(" ");
display.cp437(true);
display.write(167);
display.print("C");
display.setCursor(0, 35);
display.print("Humidity: ");
display.setCursor(0, 45);
display.print(Humidity);
display.print(" %");
display.display();
Some of the steps I have taken so far are:
Change: #include <Adafruit_SSD1306.h>
to #include <Adafruit_SH110X.h>
Change: Adafruit_SSD1306 display = Adafruit_SSD1306(128, 64, &Wire, -1);
to
Adafruit_SH110X display = Adafruit_SH110X(128, 64, &Wire, -1);
When I tried to compile the sketch after making those changes, the error message I receive is:
Compilation error: 'SH110X' was not declared in this scope
I'm really confused about what I really need to change in order to get the sketch to compile. Or if it's just not possible to use a SH1106 display in this particular situation and I'll need to order a SSD1306 and try again?
If any of you could give me any ideas of what I can do going forward, I'd appreciate it so much.
Cheers,
Amy
