I am attempting to have my Arduino Mega 2560 read a file from an SD card and play the audio through a speaker. There have been several times this has been brought up in the forum but I have not been able to resolve it with those same solutions. I am not getting any errors in the code but the file is not playing through the speaker. The speaker makes a loud buzzing sound for a 1-2 seconds and then stops. There are other sensors involved in the project that I am currently not having issues with but I am listing them in case they could somehow be a culprit or related to my issue.
All items below are being powered off the 5V Power Supply except for the SD Card Module which was initially on 3.3V but reading other forums on here it seemed like the unit I purchased could be used on 5V. Nothing is being directly powered off the Arduino Mega pins!
Solutions I have currently attempted & Other Info:
SD card was formatted set to 32FAT 11025HZ and 8bit for the audio file. It is a top level file on the card (not in a folder or sub folder)
I have tried adding a delay after the file is supposed to play as I have heard that can sometime help.
To ensure the amplifier is not defective, I tried a 2nd unit (same type) and tried using a transistor at one point as well.
I am including the code which is mostly base level right now until I can get the speaker to play files from the SD card.
I am also including a schematic to assist but am new to the Fritzing software so apologize as there were several pieces of my setup I could not find assets for in Fritzing. If there is a way to make your own custom assets, I have not gotten that far yet. Hopefully what I have makes sense though.
PARTS LIST:
Arduino Mega 2560
Breadboard
9V to 5v Power Supply module on breadboard is connected to a AC-9V DC power adaptor
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether it's working or not.
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 53
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 53;
#include <Stepper.h>
int irMotionPin = 3;
int stepsPerRevolution = 2048;
int motSpeed = 10;
int dt = 1000;
Stepper myStepper(stepsPerRevolution, 8, 10, 9, 11);
#include "SD.h"
#define SD_ChipSelectPin 53
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
while (1)
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.print("Card type: ");
switch (card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
while (1)
Serial.print("Clusters: ");
Serial.println(volume.clusterCount());
Serial.print("Blocks x Cluster: ");
Serial.println(volume.blocksPerCluster());
Serial.print("Total Blocks: ");
Serial.println(volume.blocksPerCluster() * volume.clusterCount());
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("Volume type is: FAT");
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize /= 2; // SD card blocks are always 512 bytes (2 blocks are 1KB)
Serial.print("Volume size (Kb): ");
Serial.println(volumesize);
Serial.print("Volume size (Mb): ");
volumesize /= 1024;
Serial.print("Volume size (Gb): ");
Serial.println((float)volumesize / 1024.0);
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
myStepper.setSpeed(motSpeed);
pinMode(stepsPerRevolution, OUTPUT);
tmrpcm.speakerPin = 4;
if (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD fail");
return;
tmrpcm.play("hello.wav");
delay(dt);
while (digitalRead(irMotionPin) == HIGH) {
myStepper.step(2048);
delay(dt);
myStepper.step(-stepsPerRevolution);
delay(dt);
while (digitalRead(irMotionPin) == LOW)
myStepper.step(0);
delay(dt);
I am fairly new to all this and have tried to be thorough but if you need other info or anything elaborated on definitely let me know! Also, if would be helpful, I can remove the coding pertaining to the PIR sensor and stepper motor. I left it in for now on the off chance it is somehow playing into my speaker issue. Any help or suggestions on how to address the issue are much appreciated. Thanks!
