Attempting to recreate "Falling Rain" from the Matrix for OLED - having issues
Hello,
I was trying to create that digital rain seen in the matrix movies, and the only example I could find online of that code was this YouTube video (its pretty bad in the sense the OA didn't post the code). I basically just tried to freeze frame it in order to best copy the code.
The main issue I seem to be having is at the end of the code:
"'y' cannot be used as a function...."
My goal will be to run it on an Arduino Nano with this OLED:
UCTRONICS 0.96 Inch OLED Module 12864 128x64 Yellow Blue SSD1306 Driver I2C Serial Self-Luminous Display Board for Arduino Raspberry PI
Here is the code :slight_smile:
#include <TFT_eSPI.h> // graphics and font library for 5733 driver chip
#include <SPI.h>
TFT_eSPI tft = TFT_eSPI(); //Invoke library, pins defined in user_setup.h
const int BUTTON=16;
const int LED=5;
int timedelay=25;
int height=160;
int width=120;
int y(120);
int x;
int temp;
char z;
byte randNumber; // if your random number
byte prevRand = 0; //could be initialized
void setup(void) {
  tft.init();
  tft.setRotation(0);
  tft.fillScreen(TFT_BLACK);
  tft.setTextColor(TFT_GREEN, TFT_BLACK); //adding a black
  tft.setTextSize(1);
Serial.begin(57600);
pinMode(BUTTON,INPUT);
pinMode(LED, OUTPUT);
  for (x=0;x<width;x=x+8)
          temp=random(0,height/8)*8;
          do
            y(x)=random(0,height/8)*8;
           ) while (temp!=y(x));
void loop() (
  temp = random(0,10):
                  if (temp <= 2)
                    z=('0' + random(0,10));
                  else if (temp <= 4)
                    z=('a' + random(0,27));
                  else if (temp <= 6)
                    z=('A' + random(0,27));
                    z=(' ' + random(1,220));
if (x ==16)
  tft.setTextColor(TFT_WHITE, TFT_BLACK);
  else if (x ==48)
  else if (x ==96)
     tft.setCursor(x,(/x));
    tft.print(z);
  temp=y(x)=16;
if (temp < 0)//When there is negative value
      temp= temp + height;
  else if (temp >= height)
      temp=0;
   tft.setCursor(x,temp);
      tft.print(z);
   temp=y)(x)=80;
      temp=0;
tft.print(" ");
temp=y(x)+8;
if (temp < 0) //When there is negative value
      temp=0;
y(x)=temp;
  delay(6);
I would greatly appreciate any help or tips on how to get this working.
Thanks!
Here is your code after Auto Formatting in the IDE
#include <SPI.h>
const int BUTTON = 16;
const int LED = 5;
int timedelay = 25;
int height = 160;
int width = 120;
int y(120);
int x;
int temp;
char z;
void setup(void)
  tft.init();
  tft.setRotation(0);
  tft.setTextSize(1);
  pinMode(BUTTON, INPUT);
  for (x = 0; x < width; x = x + 8)
    temp = random(0, height / 8) * 8;
    do
      y(x) = random(0, height / 8) * 8;
      ) while (temp != y(x));
        void loop() (
            temp = random(0, 10) :
                     if (temp <= 2)
                       z = ('0' + random(0, 10));
                else if (temp <= 4)
                z = ('a' + random(0, 27));
                  else if (temp <= 6)
                  z = ('A' + random(0, 27));
                      z = (' ' + random(1, 220));
                      if (x == 16)
                      else if (x == 48)
                        else if (x == 96)
                            tft.setCursor(x, ( / x));
                              tft.print(z);
                              temp = y(x) = 16;
                              temp = temp + height;
                                temp = 0;
                                tft.setCursor(x, temp);
                                tft.print(z);
                                temp = y)(x) = 80;
                                  temp = 0;
                                  tft.print(" ");
                                  temp = y(x) + 8;
                                      temp = 0;
                                      y(x) = temp;
                                      delay(6);
Note how odd it looks ?
Is something missing from what you posted ?
As to the error
instead of
int y(120);
you probably meant
int y[120];
and that relates throughout the sketch as posted
