Please, for all intents and purposes, consider me a beginner with electronics.
I am working on my first electronics project for a water filtering thing. Essentially, we are using Arduino sensors to determine water quality. If the water is too dirty, the 3-way valve will send it down one tube, and if the water is clean enough, the valve will send down another tube.
I understand how to do the coding component of this, but not the electronics/wiring part.
These are my questions:
How do I power things that don't operate with 5V? Most valves I'm seeing are 12V or 24V. I looked into it and most people suggest using relays or transistors to accomplish this. Which is better for getting a 5V Arduino to activate a 12V valve? And do I need to purchase a 5V power adapter/battery or a 12V/24V power adapter/battery?
Anything else I may need to purchase? People are saying you should have a diode with a relay, for example. And I see people using resistors as well. I already own an Arduino, breadboard, and jumper cables.
Sorry if I sound absolutely nooby. I have tried watching a lot of videos about this and I just want to make sure I know what I'm doing before I purchase materials. Thank you!
