Attiny85 Battery Tester
  • You need to measure the voltage at pin 3 of the ATtiny85 with a multimeter.
    (do you have one?)
  • You then need to download the sketch again.
    (I recommend saving it this time - it might come in useful).
  • Modify the sketch by adjusting 'FACTOR'.
  • Reprogram the ATtiny85 with the modified sketch.
  • Test to see if the results are acceptable.
  • If still not correct make further adjustments to 'FACTOR' and re-program etc.
We will help you further if you get stuck, but we would need to see the sketch to do so.
