I am new to the arduino stuff, i understands electronics very well and have been a professional developer for a year or two(In java not arduino).
I have pickedup 20 IR receivers(3-pins) and a few Attiny's and i am planning on throwing these in al my electronics to make them remotely toggleable by an apple tv remote!(ofcourse using a relais for high powered devices)
After allot of struggle getting it to upload succesfully trough an arduino ISP made from a nano3.0
I now have a problem that it wont read ANY incomming ir transmission
I have used the same code running from an arduino but it isnt working on the Attiny85
here is the code:
#include <IRremoteInt.h>
#include <IRremote.h>
int RECV_PIN = 3;
IRrecv irrecv(RECV_PIN);
decode_results results;
const int led_pin = 0;
//Serial.begin(9600);
pinMode(led_pin,OUTPUT);
pinMode(RECV_PIN,INPUT);
irrecv.enableIRIn(); // Start the receiver
long unsigned int yes = 2011265791;
boolean on = true;
if (irrecv.decode(&results)) {
//Serial.println(results.value);
if(results.value != 4294967295){
//if(yes == results.value){
if(on){
on = false;
}else{
on = true;
// Serial.print("data: ");
//Serial.println(on);
irrecv.resume(); // Receive the next value
if(on){
digitalWrite(led_pin,HIGH);
}else{
digitalWrite(led_pin,LOW);
delay(200);
Please help i dunno what todo and btw the commenting of the serial-outs were for posting it to an attiny you should uncomment those for testing on an arduino!
1kb of RAM? The chip only has 512 total. 8k flash 512 ram.
Is the attiny85 running at the same speed that you're compiling the sketch for? They ship set to run at 1mhz, and you need to select the clock speed you want, and do 'burn bootloader' to make it use that (note that if you set it to use an external crystal and don't have one connected, the chip can't be reprogrammed until you connect one, or an external clock signal).
You can run the 85 at 8mhz off internal osc, or 16 off the internal PLL (only available on the tiny x5/x61, not on most AVRs), and you may need to use one of these options for the IR library to work. Most people don't bother testing libraries at 1mhz, since almost everyone runs the chips at 8, 12, or 16.
DrAzzy:
thank you so much for a reply i messed up i tought he ment the flash and i have set it to 8mhz internally and the program is running since the led is on (by default when starting the program) so i know its there i think and i have ran a few small led based stuff on them before so i think they are ok, how exactly can i see how much ram they have left?
