IR with attiny85 do no fit (RESOLVED)
Hello, I am making a very simple project with a IR remote to control one equipment; one key switch on a pin (led) and another key switch off. I have tested this sketch in an arduino mini and its run perfectly. But because it is very simple i want to change it to an attiny85 but project do not fit:
After compiling:
In file included from /home/pedro/Arduino/ir2/ir2/ir2.ino:1:0:
/home/pedro/Arduino/libraries/IRremote/src/IRremote.hpp:281:2: warning: #warning INFO: No definition for LED_BUILTIN found -> default LED feedback is disabled. [-Wcpp]
Sketch uses 7178 bytes (87%) of program storage space. Maximum is 8192 bytes.
Global variables use 546 bytes (106%) of dynamic memory, leaving -34 bytes for local variables. Maximum is 512 bytes.
Not enough memory; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing your footprint.
data section exceeds available space in board
Compilation error: data section exceeds available space in board
I have seen some solutions on internet but I think those are a botch.
This is my code
#include <IRremote.hpp>
const int RECV_PIN = 3;	// Pin de recepción del mando
const int led =4;
//unsigned int recibido;
byte recibido;
  pinMode(led, OUTPUT);
  pinMode(RECV_PIN, INPUT_PULLUP);
  IrReceiver.begin(RECV_PIN, DISABLE_LED_FEEDBACK);  // Empezamos la recepción  por IR
  digitalWrite(led, HIGH);
      delay(100);
   digitalWrite(led, LOW);
  if (IrReceiver.decode()) {
    recibido=IrReceiver.decodedIRData.command;
    IrReceiver.resume();
if (recibido==0x45){digitalWrite(led, LOW);}
if (recibido==0x46){digitalWrite(led, HIGH);}
  delay (100);
You can see practically all memory is used by library.
¿How I can resolve this?
Many thanks.
Have you Googled or searched the forums already?
I Googled attiny85 IR Library and found this very quickly.
Yes, I have seen that page, but it is very old and the last comment (one year ago) says:
The current IRremote library was adapted to work with ATtinies out of the box, no need to download http://gammon.com.au/Arduino/IRremote_Attiny.zip any more.
For first testing use the Simple* examples from the library.
Many thanks
You may HAVE to revert to an older library of find a smaller one.
The constraints of the ATTINY 85 will always present a challenge to your coding.
A better option would be a similar board but with more memory if you cannot find anything suitable.
I resolved at last the problem.
Library load ALL protocols for IR, so I connect receiver to Arduino mini again and read in serial port the protocol uses the transmitter, in this case it is NEC, so I disabled the rest. The solution is put at the beginin of the file:
#define DECODE_NEC
After compilation only use 276 bytes (54%) of memory.
Many thanks to all answers.
