IR Remote Control using ATTiny85
Complete noobie here. I'm trying to make my ATTiny85 decode IR signals from a TSOP1738 and control LED's with it. The whole thing's very easy using an Arduino but I can't get it to work on the ATTiny85.
Using the tinyIRRemote library (Also tried Ken Shirriff's IRRemote).
#include <tiny_IRremote.h>
#include <tiny_IRremoteInt.h>
int RECV_PIN = 0;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn();
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  if (irrecv.decode(&results))
    irrecv.resume();
  if(results.value != 0 && results.value!= 0xFFFFFFFF)
    if (results.value == 0xFFA25D)
       digitalWrite(4, HIGH);
      results.value = 0;
        if (results.value == 0xFF629D)
         digitalWrite(3, HIGH);
      results.value = 0;
        if (results.value == 0xFFE21D)
            results.value = 0;
        if (results.value == 0xFF22DD)
           digitalWrite(2, HIGH);
      results.value = 0;
All it does is decode the IR signal based on the library, checks it with a set value, and turns a pin ON.
Nothing happens when I press the button. An LED connected to the signal of the TSOP1738 and ground flickers when I press the button. Everything else is fine too. I can find little help on Google.
Is it running at the speed you're compiling for? Virgin avr's come set to run at 1MHz, but you're probably compiling for 8MHz or 16MHz. On a new attiny85, do "burn bootloader" with the desired clock speed selected to set the fuses to use that clock speed.
DrAzzy:
It is. I burned it the first time (and again) at 8Mhz. I recall reading the original IRRemote used commonly on the Arduino needs 16Mhz but I think the tinyir library I'm using works at 8Mhz. Just to be clear, the code itself is fine, right? Do I need to specify #define F_CPU 8000000 at the start?
It worked! Adding
#define __AVR_ATtiny85__
at the begining made it work, for anyone who searches this up.
Thank you for your help.
