Audio input analyzed w/ Arduino FFT
Hello Arduino audio forum members,
I am working on an audio project and have reached the part where I need to do some audio processing. I have been spending some time getting the audio into the arduino with an op amp. I have it so that my audio signal going into the arduino oscilates around 2.5v and does not exceed 0 - 5v. I am working on improving the circuit for my needs but it is working and I am going to post a schematic of what I have below. Here are some resources for those that are interested.
Amanda's Instructable was a good start but she uses dual supply for her op amp and single supply makes more sense for real applications.
So this circuit comes into play for single supply op amp with the chip she uses.
http://www.rason.org/Projects/opamps/opamps.htm
and here is some good info on op amps
http://www.ti.com/lit/ml/sloa076/sloa076.pdf
Now for some reason I thought this project would be slightly easier than it is proving to be but Im happy with the learning experience and that I have a good audio signal going to A0.
After 5 hours of research I have decided that the arduino library FFT is my best best to get real time analysis of the audios frequencies. ArduinoFFT - Open Music Labs Wiki
I would like to input the audio going into A0 through the FFT functions to output real time frequencies so that I can do work with that data. Looking at functions Im not really sure where to put A0. I figured I would post this to see if anyone has any ideas on how to do this or any better places to look for an arduino to analyze audio.
Thank you for your time,
Rex
This is the schematic. It did not let me upload the image.
also, not being able to post until after waiting 10min is frustrating.
Looks like ADC0 is how we are talking about A0 in this code. Maybe a register? Anyways, I can see that the code is set up for ADC0 data to go into fft_input[].
When I try to upload example code I get "fft_input" was not declared in this scope.
I found this problem has happened before and was mentioned in arduino forum space.
http://forum.arduino.cc/index.php?topic=175219.0
I unzipped the library in the arduino library folder. This was suggested on the other forum post.
I am using mac 10.6 --> wishing I could use my chrome book even if I had to put it in Ubuntu or Mint for it to work...
The IDE I am using is Aruino 1.0.6. I believe this is the newest IDE that works on my mac.
adamatcooranbong, who posted this issue without a solution, said he used IDE Arduino 1.0, 1.0.5 and 1.5.2
Any ideas?
Post your code.
Here is open music labs example code for their fft library. This is where I get an error on fft_input
   1 /*
   2 fft_adc.pde
   3 guest openmusiclabs.com 8.18.12
   4 example sketch for testing the fft library.
   5 it takes in data on ADC0 (Analog0) and processes them
   6 with the fft. the data is sent out over the serial
   7 port at 115.2kb.  there is a pure data patch for
   8 visualizing the data.
   9 */
  10
  11 // do #defines BEFORE #includes
  12 #define LOG_OUT 1 // use the log output function
  13 #define FFT_N 256 // set to 256 point fft
  14
  15 #include <FFT.h> // include the library
  16
  17 void setup() {
  18   Serial.begin(115200); // use the serial port
  19   TIMSK0 = 0; // turn off timer0 for lower jitter - delay() and millis() killed
  20   ADCSRA = 0xe5; // set the adc to free running mode
  21   ADMUX = 0x40; // use adc0
  22   DIDR0 = 0x01; // turn off the digital input for adc0
  23 }
  24
  25 void loop() {
  26   while(1) { // reduces jitter
  27     cli();  // UDRE interrupt slows this way down on arduino1.0
  28     for (int i = 0 ; i < 512 ; i += 2) { // save 256 samples
  29       while(!(ADCSRA & 0x10)); // wait for adc to be ready
  30       ADCSRA = 0xf5; // restart adc
  31       byte m = ADCL; // fetch adc data
  32       byte j = ADCH;
  33       int k = (j << 8) | m; // form into an int
  34       k -= 0x0200; // form into a signed int
  35       k <<= 6; // form into a 16b signed int
  36       fft_input[i] = k; // put real data into even bins
  37       fft_input[i+1] = 0; // set odd bins to 0
  38     }
  39     // window data, then reorder, then run, then take output
  40     fft_window(); // window the data for better frequency response
  41     fft_reorder(); // reorder the data before doing the fft
  42     fft_run(); // process the data in the fft
  43     fft_mag_log(); // take the output of the fft
  44     sei(); // turn interrupts back on
  45     Serial.write(255); // send a start byte
  46     Serial.write(fft_log_out, 128); // send out the data
  47   }
  48 }
  49
I think that this isn't really your code. The posted code has line numbers. The compiler would balk at that before it ever looked at fft_input.
I think that either the library isn't properly installed, or the order of the #define and #include lines has been changed. You can see how to install libraries here: https://www.arduino.cc/en/Guide/Libraries. If we can see your actual code - not the code from somebody's website, but the code that you are actually compileing to get the error you mention - we might be able to figure out which it is, or whether it's something else.
I am away from my computer with the arduino IDE on it. That is the code that I copied and pasted into my arduino IDE. After pasting it I went through and got ride of the line numbers. I can paste the code without the line numbers if you think that would help.
The open music labs code has to be modified to execute properly. It should only be used as a guide.
That's good to know. I was thinking that if it compiled it would serial write frequency values. It looks like people tend to use processing to see the frequencies but that is not my intent. I would like to get values of the frequencies and their amplitude.
I was going through the FFT.h and I think tmd3 is right in saying that the #define is not working. The issue now I guess is why is this not working. I went through the steps suggested by arduino after already unzipping the folder in the libraries folder. While going through the fft.h i found that the other defined pieces (log_out and fft_n) are in this .h, I was thinking maybe they were the missing link.
Being that the library shows up in my arduino IDE its hard to believe that its not able to see and use this .h file.
Blue eyes posted the solution to this compiling issue on the originally few year old forum post (Music Labs FFT Library - Programming Questions - Arduino Forum). What a guy. or girl?
Anyways the solution to anyone experiencing compiling issues with the FFT library is to remove the FFT folder inside the ArduinoFFT2 folder. I now have both the FFT and ArduinoFF2 folders in the library folder and it compiled just fine. So it must be that the arduino IDE does not look farther than one folder in the main library folder.
Ok so now that the FFT examples have compiled I am not sure what is going on with the output. I have my audio so nicely entering the arduino A0 pin at a 2.5 middle not exceeding 0 or 5v.
here is the code straight from the FFT library example
fft_adc.pde
      byte j = ADCH;
    sei();
and here is the serial print data... WOW weird symbols. Its like a printer gone mad.
µ! ?ähòLy‚K ;™k´Ímªˆ œiv’þ p ¢ üJ / ØìŸ?=Ÿnéýeéÿc €xâ1Ëôÿ €Š ®PN~ ÇK– “þ F ©:$³Ã© $ QØ£R $”2´,}C À¤Ì ’ EŸá² ÿŠ€ À–Ÿ²“ù×k €òáš× -ð à … &D mÃ'0ÿ  A & ÿ$ › Ö-ãMl¤ …ýh Ô ¬ % B@- z [¤*ˆ=¼ þ
á ½ß“¤Jrû)$ mR&ÿGAÓ Ã–ŠQ¸Ž•[=Û™-ÿ 8p @Ðh ϰÊ<‹"iš,BžT. ”{( ð Æz0-FÃ8øcÛ¢(€‹Oþ ï < –'5BP; f§Â–6 " rƒ®ŒšE6š„x+8 ÐZÃ:$°†m¸ è¤ï+;p; Hý£C !˜‹6ÂúÒË C‰zÎß’N ÑR Àʯ9H˜ÿ# 0 ©w‰ k p –.MÏ$š›*… ÊC°Kÿš !›<š þ…! €2Ò $Z ¹@ HŸI 9øß" ˜G¸áó ‚ k>m ÓA D)SïK ± Ë Ò´à ÍŽZbd @ € W-É ãì E@/ –ÿ)¥ D@ƒli–ªýi €$÷ ÇN$) €N8„’Ó" Ds{•Ùžûla)0ìÝ*(@à åûOܬ , (>lM ÿÖ B ›³É %D ©Ö" H“ –k T= ü¥ˆ°Ê0€N €/ š¬(þbB €B I’"@ $u§— ÿ\<‚„(h¶ Á: É­´ €þ ‘@ß ­õV‚ € ¨WX €ÿÖ$ A ÌAPÅ ã ãÁÿ† ý  X ã 9 Pþ)ñ @ JœmÈ‚€" jO·"—ü @ µ†Kˆ´ÿP d šLg% T ! Ÿ”eü „t 6 Ô4@ D ¢ HW$@ÿ/‘ H WÛš!Aþ„ M9 …ÿ¦—O5 ùÆ!Fçž V ÿ D$¥ ¤XÄÿ AË ð !¥ b æ @ {OÁ é Ïì @ t£ ÖÒ"‘ …qz q2ü4 Oâ*Ù ýPHŠ)=—È1ûa ¸ŽÂ°¤ 4 kò5“Èò i ¿Ÿ“ÌÊIF’€ Ô Ñ‰«Þ¢ ;Èm$e$ 9 n’ ó DB°4NhJ$ |ã(Z‚þA áÁ’ 1 Ï7 ½l” i „S ‘$@Z
'áãÿ¤‹ Рܹÿ È:¶ù«ˆ×=ÿRšK €O[ [¼ŒH a “åÅQkÿ
SóxJÉ€ MC2
®$ ¼çÒu¸Í „¸\— N3 ÅSŸëJþÁò€ @Ÿ¨bóN…$ l—ÊCÔ y€€âÉM mÍA ” zp,^ p Ò Ê° ,@ ³ È,S™€ $C¶ žš
˜=Æèûi X …%#dÒ Ï0 ž1¼ ÿ €° /BXíÞ Üy‚ ÄôO‚ Íw5-ÿ²DŠD Û´Ò7 ø(7‚e ‹ ý‰ Ú Ûþ” "æçÿ’-ÿÉ 8 %ÛJ!”ýŸ6à @•—h²ùZV) AžY x”k {‰ŒX€ÿ ‚ § €I6 ¤ LF # !ÂöRZ7í7Ø Ó> ,[ÿËä‚”À ƒøúêÏaj tiç yˆ $J¥ÛÐ:äu ¢Oä)öI^Dž"í– “EüÚ € íÙ 3ã @‰ –x¶’ZLl D[¼” Ú – €z{–‚@;¤ l MŒýK 1 , òÅÆ D>MÛòU r M /Èø¼ & V % ’± ÀØ„ºuèî @+ $ZWxÿ! ~ÀQ R–v $xŠ” òj D Þ ¯1„Ò @€yÄšÄöiC $ÈPbÂÿz¥KÛ X $ M å„•€ @0Ð)€ Nh {Hà, ( EÒ üT’” Ä ¾rF±e ²<ª²ÀÂ@Ð!z \„P@D ¹òÜh ü @Ú ÿP œ … Ò“€ §Î(,šˆkH„ yQƒ ©T R ­CB þC‚‚ hP4 ÿ2J € á¨#Yˆ D º ¦$ ÿV€ ã>v ²IR% @Aà‘ ÞðH ƒã ÿ @ ‚†I *°0 µ=CB‰þÖ0L€€­6z/Ûþ% êe ›{ô< ’ ¢JžU.¤˜ ¶ à Û! ÚN2É @¶ <þ Yæx À î 9Èh D ¬à ä! @ Á†q-Ë) € I äœvÿ e3< @ÿ, ,¥Ðû œ ˆ ‰Y™ T " Ä ¼‚ÛM A± - úà…@ Í è(øY ¿Øt éF0 € ’P ÊÞ ‘@¶ ÿR 2 ¡(HB‚þa$"K€è…!ø) @%ŸLò ÿik1 Büi- c…F » ÕL«þÞ ¨ M>K ´þ®) 2 _ÑÂÏ” !" i¾±Ël … —‘ ¥È ÈøúÔ[4ÿV3 ©Ùm’C k€ä ¶ Œ K @j»J ò ¸4¢ $ú
F€ H nWB
a2
ܼ¥X(ˆ P¯ y!h- €„D ž R߯)€Zn Ÿï HP‚žH=rõB ÛC™ÿ A €@ î bà Hl3„“d¬ â4 ¥[M iËy›ð# @$À7 5¡‹Ñ*$@€ ›œ µþJ D0 š @ ã' ägŠiþ¶ €JúŠ0ôÿk| ¶ ÿŽI€ "­ núT$ Ý’ž ž DëX”qÊüi; b%d •ÿo) V ƒE#ÿÞ, 5Ñ Ê þᎠ€œVž€ÿ¯¤ B L­š/ù @ À ˆ€@ÿM # A¶N °HbM b kây Cóƒ DY a Jÿ „à­¤ÿ’Å# €8…%lÈ * $\f D@ùs ãÿ]
ÙIÎ’þŒ* ­‘@ Èa@ ô¼ÈiêX ä : þ D mX²¬ŸüK B" Î…¥Ù€ ƒ65@(ÿ‘@! rÍ¢x Ir€ ù mÿ¥ J ã< ºZE O6ȼނ0PHÇ$ ²N #¤Ó% W I ’a¤ ƒ€ >­IÒ2 „ * X(H ý @’âAâ ÿ 8 ‚-† Ð M 0ÿ 1„ÈWõ FÖ K ר-ÿiR Jÿm¬4¤ý.( ƒØ ¤5%@ ¯ÛL%õ9 Mg [i)€ Á ñ: Þ<B b A(S2‘×ý‚0! ó’
J B‡ƒ ˆ 9JI $ÿL T†›E ñ @ |ˆ ¤Óÿ ( #G Jü" #Z¼@$ÿ* Å‚I’„F „åijX” @
Ê¥² ÿ l€F€ 9hÖš# 5Q:H @ Ú Ç²¹a \” ÎôZ ø”¼†À € ¸Z°ySÿa‚ -øt õ ƒ àAÃKJ{A!0 ,7 êR ‡‘r~Ä – Jß BÐJ @€p %2 ÿ† € r=jÒyž kz {Xÿ6 €xkSëÓ, )<O HÇÿò D‚ È&1J ‡€€¬I”|˜ ,J(K×7šˆD 0 hXs4þh‚L €k‚Ô‚éa Øô ú ø d@¶gÀ‡þÞD {“D Ïýø ( Hè(‰èþ( B ~ŠMÓ° 4@õQ÷äÐþL " ši]ù‹ " Õq ™‘ KþO³,‰ €”2 ”Ha}%F Â(X¡" LMÑ Vÿb K œEÿ¶ h |€Ä € C =È)SR xº ¤ þx €[eš šZI ìKd)ÆÚ!€Hz” d‚I )š „ C†£@ !9^XjŽ V€DI ÏÁIl B-@%NA+f Êx)! ðÀi[$ø ˆ §kÆ ÿN0 € XHt €{­²) þ hÀIŒ !ÒV“ €8‹… × K à› ,¥´dt éb aý‚ @D I þ 3 @¼Y8Á<ÿ Ý(z¬½ûÅ ¢ µ-lѰ K %Ó¢üŒTp7 ž ú¶ $@Ù͇­È [& -ÚY i @ ‡S „KIy‚!y € yJ‚ÆKð‚ ! NX AÿR „ ¤ƒ<‚ òl ©OJ B „ z Þl € Ò[‡yC € ÐŒ©Ïzñª € b,¥¤Íb!6iËÑÉZ € ÓHRWTþÏ© €ÙµÂ ÷²@ HŸ,+ r †n†ÿö’ ¤ !LKñ iª, О” Ä
Seril.write() isn't the same as Serial.print(). Check the difference in the Reference pages. Serial.write() sends unmodified data; Serial.print() sends an ASCII representation of the value, generally human-readable.
To see the output, you'll have to replace the two Serial.write()'s with a loop that Serial.print()s those values.
[Edit: grammar]
Serial.print(255) and Serial.print(fft_log_out,128) gives an error of "call of overloaded 'print(uin8_t[128])' ambiguous.
Check the Reference page(s) for how to use Serial print(). Replace the Serial.write() instructions with this:
    for (uint8_t j = 0; j < FFT_N/2; j++) {
      Serial.print(j);
      Serial.print(" ");
      Serial.println(fft_log_out[j]);
Note that it'll print a lot of data, quite fast.
Thank you for coming up with a for loop for me. J goes to 127 and I am not sure what fft_log_out is printing in relation to j. I got frequencies printed from this code written by hongp (forum.arduino.cc/index.php?topic=175679.new#new) but his code is made for a specific school project involving pumps. His code prints just one freq at a time and its kinda slow, but it pushes out a freq.
When I first tried your for loop, tmd3, I got the same type of characters on the output. I was trying to take out pieces of hongp's code to see if I could get a freq value. Still garbage. I realized that the Serial.begin was different than the examples so I changed it too 9600, which is the usual. then your for loop and many other things I tried gave real numbers rather than strange characters.
115200 = no good for reading serial print ---- 9600 = readable serial print
doing a frequency test that goes through all of the audible frequencies through hongp's code pushes this.
37hz - 111hz - 148hz -185hz - 222hz - 259hz - 296hz - 333hz - 370hz - 407 hz - 444 hz - 481hz - 518hz - 555hz - 592hz -629hz - 666hz - 703hz - 740hz - 777hz - 814hz - 851hz - 888hz - 925hz - 962hz - 999 hz - 1036hz - 1073hz - 1110hz - 1147hz - 1184hz - 1221hz - 1221hz - 1258hz - 1295hz - 1369hz - 1406hz - 1480hz- 1517hz - 1554hz
until hitting 4699 and dropping back down. This probably has to do with his int resolution, removing this does not give good results.
I think I will need to spend a good amount of time learning FFT and how it works to really be able to get into this code. I was thinking that I was going to easily find frequencies with it, at least by simply going through a frequency test.
//UNO clock Frequency = 16 MHz
//It takes 13 clock cycles to finish analog reading
int refFrequency = 0;
int currentFrequency = 0;
int previousFrequency = 0;
int errorFrequency = 0;
int refState = 0;
int currentState = 0;
int tunningState = 0;
boolean inRange = false;
float P = 0;
float I = 0.0;
float D = 0.0;
float drive = 0;
int pwmDrive = 0;
const int refInput = 8;  //reference pin
const int currentInput = 9;  //final pin
const int ForMotorControl = 10;  //pump control pin PWM
const int BacMotorControl = 11;  //pump control pin PWM
const int tunning = 12;  //tuning control pin
int bin = 0;
int frequency = 0;
int resolution = 9615 / 256;
int maxLogOut = 0;
  Serial.begin(9600); // use the serial port
  pinMode(refInput, INPUT);
  pinMode(currentInput, INPUT);
  pinMode(tunning, INPUT);
  pinMode(ForMotorControl, OUTPUT);
  pinMode(BacMotorControl, OUTPUT);
  ADCSRA |= (1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0); //set adc prescaler=128
  ADCSRA |= (1<<ADATE);  //enable auto trigger
  ADCSRA |= (1<<ADEN);  //enable ADC
  ADCSRA |= (1<<ADSC);  //start ADC measurements
    //sampling
      ADCSRA |=(1<<ADSC); //start ADC measurements
      byte j = ADCH;
    }//end of for
    //FFT
    sei();
    maxLogOut = 0;
    for(int i = 1; i < 128; i++){
      if(fft_log_out[i] > maxLogOut && fft_log_out[i] > 150){
          maxLogOut = fft_log_out[i];
          bin = i;
      }//end of if
    }//end of for
    frequency = bin * resolution;
    if(frequency > 1500 && frequency < 2700){
      inRange = true;
      inRange = false;
    //if digital pin 8 is high, set the reference frequency
    //if digital pin 9 is high, set the current frequency
    //if digital pin 12 is high, set tunning state = high
    refState = digitalRead(refInput);
    currentState = digitalRead(currentInput);
    tunningState = digitalRead(tunning);
    if(refState == HIGH && inRange == true){
      refFrequency = frequency;
    } else if(currentState == HIGH && inRange == true){
      currentFrequency = frequency;
    } //end of else if
    //error tracking
    //highest frequency = (2405)2479 hz  lowest frequency = (1517) 1628 hz
    errorFrequency = refFrequency - currentFrequency;
    P = errorFrequency;  //proportional term
   // I = Integral * 0;  //intergral term
   // D = (previousFrequency - currentFrequency) * 0;  //derivative term
   // previousFrequency = currentFrequency;
    drive = P * (255.0/888.0); //scaleFactor = 255 * 888;
    //start tuning if tunning state = high
    if(tunningState == HIGH){
    //motor control
      if(errorFrequency > 30){      //pump liquid out
        //digitalWrite();  //pump in one direction
        digitalWrite(BacMotorControl, HIGH);
        analogWrite(ForMotorControl, 0);
      } else if (errorFrequency < -30){  //pump liquid in
        //digitalWrite();  //pump in another direction
        digitalWrite(BacMotorControl, LOW);
        pwmDrive = (int)abs(drive);
        if(pwmDrive < 80){ pwmDrive = pwmDrive + 80;}
        analogWrite(ForMotorControl, pwmDrive);
      } else {  //stop pumping
        analogWrite(ForMotorControl, 0);  //stop the motor
    //debug
    Serial.print("frequency: ");
    Serial.print(frequency);
    Serial.print(" | ");
    Serial.print("reference frequency: ");
    Serial.print(refFrequency);
    Serial.print("Current frequency: ");
    Serial.print(currentFrequency);
    Serial.print("error frequency: ");
    Serial.println(errorFrequency);
  }//end of while
}//end of loop
rexhex:
Look at the lower right corner of the serial monitor window. You'll see an indication of the baud rate. That rate needs to match the value that you used in the Serial.begin() in your sketch. If you select that pulldown menu, you'll see a list of baud rates that the Arduino is friendly with.
Your code has this line:
That means that you'll have to use 9600 on the serial monitor as well. If you want to use
you'll have to select "115200 baud" in the serial monitor.
You can see how to use Serial.begin here. You can find links to Serial.write(), Serial.print(), and other Serial methods here.
I will read up on the serial.___ so i hopefully don't make any more mistakes there. I have never needed to change that up until now. In my free time today I have been reading about FFT and its pretty interesting stuff.
This is in the readme in the fft library folder. A good source for sure.
http://www.alwayslearn.com/dft%20and%20fft%20tutorial/DFTandFFT_BasicIdea.html
tmd3, thank you for responding and helping me out with this. :slight_smile:
So I have been going through hongp's forum and a lot of my questions have been answered. It looks like FFT with the arduino is not powerful enough for my goal. "For each 'bin' N the frequency is N * Sample_Rate / FFT_Size" - johnwasser. We are limited to the number of frequencies we can look at because we can only really look at 127 different frequencies because the bin represents the frequency it is measuring.
Im attempting to get frequencies out of music for a light show. I want create code that reacts to different frequency ranges. The first step I want to get done is something like 20hz - 60hz = sub bass response : 60hz - 250hz = bass response : 250hz - 2khz = midrange response : 4khz - 6khz = high midrange response : 6khz - 20khz = high frequency response.
With the arduino and FFT it looks like I would be able to get a response from these 5 categories if the artist hit specific frequencies in these catagories. "...the highest number of elements that is "guaranteed" to work is, in fact, 445..." (Arduino Playground - CorruptArrayVariablesAndMemory).
This dose not make for an organic feel. Maybe I will need to go analog to digital? I hope that I am not seeing this right but am pretty sure its true. FFT with the arduino only looks at very limited frequency ranges and ignores all of the rest.
No, read about FFTs again, that is wrong. In fact it is the total opposite an FFT looks at all frequencies but only gives you the result in bins.
