Autodesk Eagle Drawing Software
Hi
I am using Eagle 9.5.1 drawing program, I am doning a schematic, but I need to get it into a project but don't seem to be able to copy the schematic to a project name, should I of made the project name first, then create the schematic ?.
Any help on this, not sure if anyone on here uses Eagle though !.
cheers
Spike
I think you need to create a new project and then import the schematic into it.
What format is your schematic saved in now?
Hi
Thanks for your reply, it is in " Eagle schematic " format.
cheers
If I click on a new project name, there is no option to import !
I don't understand, what are you doing...
  • You have to open a project in the Eagle
  • Go to File menu - Import
  • Select format and choose the file
Hi
That option is not there
Sorry, I can't test it, I havent an Eagle on my PC just now...
I'm stuck at pre-autodesk EAGLE (7.3), but isn't a "project" just a directory containing a .epf file? You can copy/rename/re-save schematic or board files into that directory, or you can drag and drop them in the "Control Panel."
