Automatic Dog Feeder
The water wheel dispenses dog food.
There is a continuous servo on each side of the pvc pipe. This is a rough prototype. Version 2.0 will have a smaller space for food to pour through and a smaller wheel to dispense more accurate amounts of food a bit at a time.
It can be programmed to turn on at any time and on any day.
//Automatic Dog Feeder.
//It can be programmed for any time and any day
#define servo1control OCR1A       // servo1 is connected to Arduino pin9
#define servo2control OCR1B     // servo2 is connected to Arduino pin10
//servo constants -- trim as needed
#define servo1null 3035
#define servo2null 3035
// Most servos are analog devices so the exact null point may vary somewhat device to device.
// This is particularly true of continuous rotation servos.
unsigned long now = 0;
unsigned long then = 0;
unsigned long rollover = 0;
unsigned long stoptime = 0;
int seconds = 0;
int minutes = 0;
int hours = 0;
int days = 0;
int weeks = 0;
int oldseconds = 0;
int oldminutes = 0;
int oldhours = 0;
void setup(){
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  TCCR1B = 0b00011010;          // Fast PWM, top in ICR1, /8 prescale (.5 uSec)
  TCCR1A = 0b10100010;          //clear on compare match, fast PWM
                                // to use pin 9 as normal input or output, use  TCCR1A = 0b00100010
                                // to use pin 10 as normal input or output, use  TCCR1A = 0b10000010
  ICR1 =  39999;                // 40,000 clocks @ .5 uS = 20mS
  servo1control = servo1null;         // controls chip pin 15  ARDUINO pin 9
  servo2control = servo2null;         // controls chip pin 16  ARDUINO pin 10
void loop(){
  now = millis();
   if (rollover > now){  // this takes into account the eventual
   then = rollover;      //  millis rollover
   rollover = millis();
  if (now - then >= 1000){
Serial.print("Hours: ");
  Serial.println(hours);
Serial.print("Minutes: ");
  Serial.println(minutes);
  Serial.print("Seconds: ");
  Serial.println(seconds);
//Serial.print("Days: ");
//  Serial.println(days);
  seconds ++;
  then = now;
  if (seconds >= 60){
  minutes++;
  seconds = 0;
if (minutes >=60){
 hours++;
 minutes = 0;
if (hours >= 24){
days++;
hours = 0;
if (days >=7){
   weeks++;
    days = 0;
  // Max Speed is 4035 or 2035, 3035 is stationary
  if (hours == 0 && minutes == 0 && seconds == 0){
    stoptime= now + 1000;  //set duration of dispensing (1000)
    //TURN ON THE DOG FEEDER
  if (now < stoptime){
  servo1control = 2035;             // valid range is servonull +/- 1000
                                   //  - is counter clockwise
                                   //   + is clockwise
                                   // The difference from servonull represents servo angle or,
                                   //for continuous rotation servos, speed.
                                   //These values may differ somewhat unit to unit
  servo2control = 4035;
  now=millis();
 Serial.print("Stoptime: ");
  Serial.println(stoptime);
  Serial.print("Now is: ");
  Serial.println(now);
Cool, now how about the dog's water dish?
Lefty
