Automatic plant irrigation
Hello fellow Arduino programmers :slight_smile:
I'm new to Arduino, and I'm interested in starting my first project. I have no experience at all with Arduino, and I'm not sure where and how to start. I would appreciate any kind of help. So before I start, excuse me for the newbie questions :smiley:
I searched for previous threads on this topic, but I wasn't sure they exactly match my case.
My idea is to building an automatic plant irrigation system for my balcony. I have around 20 different plants that differ by size and water requirements. I thought about adding a soil moisture sensors and valves that would help regulate the water to each plant. I am clueless about which Arduino is right for this project, and which other components are necessary. I'm okay with starting with a few plants at first to see that everything works fine, and later expand the system to more plants. I also thought about adding a solar panel to power the system at later stages.
I would appreciate if you guys could help me with choosing the right Arduino and additional components for this project, and how to start building it.
In order to keep the drawing clear, I have not included the wires from the moisture sensors to the Arduino in the attached picture.
If you really want to do it with one Arduino, it will be tricky. The number of pins required would suggest that you need one for each valve (at least) and one for each moisture sensor which will probably be an analog sensor. That suggests a Mega, but even that only has sixteen analog inputs. Also you'll have a bunch of long wires all over the place.
I would be more inclined to get several WiFi equipped devices and have each one do several plants. One of them can be the pump controller as well. That way you can start with two and build up as you discover what works. Maybe a nice cheap Wemos D1 mini, or one of the ESPXX range.
Hello
at least you need a small HMI to set the parameters, too.
I don't think wireless is a good idea. Wireless sensing needs to get power somehow. Getting power from mains via wires defeats the purpose of being wireless so it must be batteries or some power harvesting. This adds a lot of complexity. Since there will be some tubing for the water running wires parallel with the tubes adds little complexity or ugliness.
A small MCU may be at each plant reading moisture sensor and doing all the calculations locally, sending requirements to a central MCU which will control the water flow. Implementing some bus system makes this easily extendable.
The other option is a single MCU doing all the work possibly with help of shift registers, I/O expanders and/or analog multiplexers.
I don't think noise on long wires is such problem. The application is very slow - you have hours, maybe even days to react! You can apply any sort of HW or SW filtering such as reading each sensor 100000 times and use average value.
It is said the cheap resistive soil moisture sensors are useless due to quick corrosion of the electrodes. Some sort of capacitive sensing with waterproof electrodes is probably the way to go - but I have no practical experience with this.
First here is the task running that does the thing:
part 1
#include <ESP32Time.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection infor for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
WiFiClient      wifiClient; // do the WiFi instantiation thing
PubSubClient    MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32Time       rtc;
#define evtDoParticleRead  ( 1 << 0 ) // declare an event
#define evtADCreading      ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_RemainingMoistureMQTT;
QueueHandle_t xQ_RM;
QueueHandle_t xQ_Message;
struct stu_message
  char payload [150] = {'\0'};
  String topic;
} x_message;
int    mqttOK = 0;
bool   TimeSet = false;
bool   manualPumpOn = false;
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', 150 );
  x_message.topic = ""; //clear string buffer
  x_message.topic = topic;
  int i = 0;
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  x_message.topic.reserve(150);
  xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
  xQ_RemainingMoistureMQTT = xQueueCreate( 1, sizeof(float) ); // sends a queue copy
  xQ_RM = xQueueCreate( 1, sizeof(float) );
  eg = xEventGroupCreate(); // get an event group handle
  sema_mqttOK =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pull_down_en = GPIO_PULLDOWN_ENABLE; // enable pull down
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
  io_cfg = {}; //set configuration structure back to default values
  io_cfg.mode = GPIO_MODE_OUTPUT;
  io_cfg.pin_bit_mask = ( 1ULL << GPIO_NUM_4 | (1ULL << GPIO_NUM_5) ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
  gpio_set_level( GPIO_NUM_5, LOW); // deenergize valve
  // set up A:D channels  https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 10000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fPublish, "fPublish", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fReadAD, "fReadAD", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoMoistureDetector, "fDoMoistureDetector", 70000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
} //void setup()
void fReadAD( void * parameter )
  float    ADbits = 4095.0f;
  float    uPvolts = 3.3f;
  float    adcValue_b = 0.0f; //plant in yellow pot
  uint64_t TimePastKalman  = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
  float    WetValue = 1.07f; // value found by putting sensor in water
  float    DryValue = 2.732f; // value of probe when held in air
  float    Range = DryValue - WetValue;
  float    RemainingMoisture = 100.0f;
  SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
  for (;;)
    xEventGroupWaitBits (eg, evtADCreading, pdTRUE, pdTRUE, portMAX_DELAY ); //
    adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
    adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
    KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
    TimePastKalman = esp_timer_get_time(); // time of update complete
    RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture =  1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
    xQueueOverwrite( xQ_RM, (void *) &RemainingMoisture );
    //log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
  vTaskDelete( NULL );
void fPublish( void * parameter )
  for (;;)
    if ( xQueueReceive(xQ_RemainingMoistureMQTT, &RemainingMoisture, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
  } // for (;;)
} //void fPublish( void * parameter )
void WaterPump0_off()
  gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
  vTaskDelay( 1 );
  gpio_set_level( GPIO_NUM_5, LOW); //denergize/close valve
void WaterPump0_on()
  gpio_set_level( GPIO_NUM_5, HIGH); //energize/open valve
  vTaskDelay( 1 );
  gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 12;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 5000; //delay for mS
  for (;;)
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
part 2
void fDoMoistureDetector( void * parameter )
  //wait for a mqtt connection
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  int      TimeToPublish = 5000000; //5000000uS
  int      TimeForADreading = 100 * 1000; // 100mS
  uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
  uint64_t TimeADreading   = esp_timer_get_time();
  const TickType_t xFrequency = 10; //delay for 10mS
  float    RemainingMoisture = 100.0f; //prevents pump turn on during start up
  bool     pumpOn = false;
  uint64_t PumpOnTime = esp_timer_get_time();
  int      PumpRunTime = 5000000;
  uint64_t PumpOffWait = esp_timer_get_time();
  uint64_t PumpOffWaitFor = 60000000; //one minute
  for (;;)
    //read AD values every 100mS.
    if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
      xEventGroupSetBits( eg, evtADCreading );
    xQueueReceive(xQ_RM, &RemainingMoisture, 0 ); //receive queue stuff no waiting
    //read gpio 0 is water level good. Yes: OK to run pump : no pump off.   remaining moisture good, denergize water pump otherwise energize water pump.
    if ( RemainingMoisture >= 40.0f )
      WaterPump0_off();
    if ( !pumpOn )
      log_i( "not pump on ");
      if ( gpio_get_level( GPIO_NUM_0 ) )
        if ( RemainingMoisture <= 20.0f )
          //has one minute passed since last pump energize, if so then allow motor to run
          if ( (esp_timer_get_time() - PumpOffWait) >= PumpOffWaitFor )
            WaterPump0_on();
            log_i( "pump on " );
            pumpOn = !pumpOn;
        //xSemaphoreGive( sema_RemainingMoisture );
        log_i( "water level bad " );
        WaterPump0_off();
         pump goes on runs for 5 seconds then turn off, then wait PumpOffWaitTime before being allowed to energize again
      if ( (esp_timer_get_time() - PumpOnTime) >= PumpRunTime )
        log_i( "pump off " );
        WaterPump0_off(); // after 5 seconds turn pump off
        pumpOn = !pumpOn;
    // publish to MQTT every 5000000uS
    if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
      xQueueOverwrite( xQ_RemainingMoistureMQTT, (void *) &RemainingMoisture );// data for mqtt publish
      TimePastPublish = esp_timer_get_time(); // get next publish time
}// end fDoMoistureDetector()
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; // 250mS
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
  vTaskDelete ( NULL );
void connectToMQTT()
  // create client ID from mac address
  byte mac[5];
  int count = 0;
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]);
  log_i( "connect to mqtt as client %s", clientID );
    MQTTclient.disconnect();
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
    count++;
    if ( count == 5 )
      ESP.restart();
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      if ( px_message.topic == topicOK )
        mqttOK = 0; // clear mqtt ok count
      if ( !TimeSet )
        String temp = "";
        temp = px_message.payload[0];
        temp += px_message.payload[1];
        temp += px_message.payload[2];
        temp += px_message.payload[3];
        int year =  temp.toInt();
        temp = "";
        temp = px_message.payload[5];
        temp += px_message.payload[6];
        int month =  temp.toInt();
        temp = "";
        temp = px_message.payload[8];
        temp += px_message.payload[9];
        int day =  temp.toInt();
        temp = "";
        temp = px_message.payload[11];
        temp += px_message.payload[12];
        int hour =  temp.toInt();
        temp = "";
        temp = px_message.payload[14];
        temp += px_message.payload[15];
        int min =  temp.toInt();
        rtc.setTime( 0, min, hour, day, month, year );
        log_i( "%s  ", rtc.getTime() );
        TimeSet = true;
      //manual pump control
      //    if ( str_eTopic == topicPumpState )
      //      if ( String(strPayload) == "off" )
      //        WaterPump0_off();
      //        manualPumpOn = false;
      //      if ( String(strPayload) == "on" )
      //        WaterPump0_on();
      //        manualPumpOn = true;
      //xSemaphoreGive( sema_MQTT_Parser );
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
I originally bought this kit the kit I bought which came with wonderful capacitive sensors. I, carefully, covered the exposed electronics with hot glue. The motors suck.
I got these motors the motors I used.
Then I found each motor creates a siphon that causes water to flow when pump is off and overwaters the plants so I got this valve
I found it takes some time for the water to soak into the soil and effect the sensor reading. I run the pump for 5 seconds, wait one minute and check if the more water is needed.
reservoir water level sensor
motor and valve, the black wire snaking over the yellow flowerpot goes to the capacitor sensor.
project in box
ESP32 with WiFi and connecting to MQTT for publication and subscription.
A AC to DC 5V switching regulator and a relay module can be seen.
OP will want some sort of switching device to energize the motors and valves, such as relays.
Solar power would be an excellent choice for this project. I run a solar powered weather station. I use 30W solar panels feeding into a PWM Solar Charge Controller. The PWM controller supplies a 12V LiFePo4 16Ah battery, the battery supplies the rest of the components.
