I’m hoping someone can help point me in the right direction. I’m brand new to the Arduino world, but do have a solid understanding of electronic components and how they operate. I'm a ham radio operator if that should earn me any points. Here is what I’m wanting to build.
I’d like to create a simple remote plant watering system that I can activate over the internet (web based is fine, an app would be great but not necessary). It does not need to be automated, as I have a Wifi camera monitoring the plant and I’ll know when water is needed. I suspect that I need a peristaltic pump as part of the build, but that’s where my knowledge ends. I’m not sure which Arduino board to go with, how to code it etc. If you know of any projects out there that are even remotely close to what I’m searching for, please send them my way.
Any and all suggestions are welcome, and let me know if you need additional clarification.
Thanks!
Type of pump depends what water source is available. If mains water with good pressure is available, or a supply tank mounted high up so that a head of pressure is available, a solenoid valve would be appropriate.
For a low level supply tank, a submersible dc pump would suit.
Not sure why you think a peristaltic pump would be approprate, please explain.
Hi, I would suggest you go through this article (link is below). It shows how to make an automated irrigation system using a NodeMCU, some sensors, a water pump. You can modify it as per your requirements.
Here is some automated plant watering code using an ESP32. I have incorporated code to receive MQTT messages but have not done anything with it yet. The MQTT is to allow remote control of the watering system.
#include <ESP32Time.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection infor for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
WiFiClient wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32Time rtc;
#define evtDoParticleRead ( 1 << 0 ) // declare an event
EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
int mqttOK = 0;
bool TimeSet = false;
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
mqttOK = 0;
xSemaphoreGive( sema_mqttOK );
if ( !TimeSet )
int i = 0;
char strPayload[length + 1];
String temp = "";
for ( i; i < length; i++)
strPayload[i] = ((char)payload[i]);
strPayload[i] = NULL;
temp = strPayload[0];
temp += strPayload[1];
temp += strPayload[2];
temp += strPayload[3];
int year = temp.toInt();
temp = "";
temp = strPayload[5];
temp += strPayload[6];
int month = temp.toInt();
temp = "";
temp = strPayload[8];
temp += strPayload[9];
int day = temp.toInt();
temp = "";
temp = strPayload[11];
temp += strPayload[12];
int hour = temp.toInt();
temp = "";
temp = strPayload[14];
temp += strPayload[15];
int min = temp.toInt();
rtc.setTime( 0, min, hour, day, month, year );
log_i( "%s ", rtc.getTime() );
TimeSet = true;
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
sema_mqttOK = xSemaphoreCreateBinary();
gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0)); //bit mask of the pins to set, assign gpio number to be configured
gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
io_cfg = {};
io_cfg.mode = GPIO_MODE_OUTPUT;
io_cfg.pin_bit_mask = ( 1ULL << GPIO_NUM_4 ); //bit mask of the pins to set, assign gpio number to be configured
gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
// set up A:D channels https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
adc1_config_width(ADC_WIDTH_12Bit);
adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 20000, NULL, 6, NULL, 1 ); // create and start the two tasks to be used, set those task to use 20K stack
xTaskCreatePinnedToCore( fDoMoistureDetector, "fDoMoistureDetector", 10000, NULL, 3, NULL, 1 ); // assign to core 1
xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 3, NULL, 1 ); // assign all to core 1
} //void setup()
void fmqttWatchDog( void * paramater )
int UpdateImeTrigger = 86400; //seconds in a day
int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
int maxNonMQTTresponse = 12;
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = 5000; //delay for mS
for (;;)
vTaskDelayUntil( &xLastWakeTime, xFrequency );
xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
mqttOK++;
if ( mqttOK >= maxNonMQTTresponse )
ESP.restart();
UpdateTimeInterval++; // trigger new time get
if ( UpdateTimeInterval >= UpdateImeTrigger )
TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
UpdateTimeInterval = 0;
vTaskDelete( NULL );
} //void fmqttWatchDog( void * paramater )
void fDoMoistureDetector( void * parameter )
//wait for a mqtt connection
while ( !MQTTclient.connected() )
vTaskDelay( 250 );
int TimeToPublish = 5000000; //5000000uS
int TimeForADreading = 100 * 1000; // 100mS
float WetValue = 1.35f; // value found by putting sensor in water
float DryValue = 2.732f; // value of probe when held in air
float ADbits = 4095.0f;
float uPvolts = 3.3f;
float adcValue_b = 0.0f; //Jeanne's plant in yellow pot
float Range = DryValue - WetValue;
float RemainingMoisture = 100.0f; //prevents pump turn on during start up
int printCounts = 0;
uint64_t TimePastKalman = esp_timer_get_time(); // used by the Kalman filter
uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
uint64_t TimeADreading = esp_timer_get_time();
const TickType_t xFrequency = 10; //delay for 10mS
SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
for (;;)
//read AD values every 100mS.
if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
TimePastKalman = esp_timer_get_time(); // time of update complete
RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture = 1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
//read gpio 0 is water level good. Yes: OK to run pump : no pump off. remaining moisture good, denergize water pump otherwise energize water pump.
if ( gpio_get_level( GPIO_NUM_0 ) )
if ( RemainingMoisture >= 40.0f ) {
gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
if ( RemainingMoisture <= 20.0f )
gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
log_i( "water level bad " );
printCounts++;
if ( printCounts == 100 )
log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
printCounts = 0;
// publish to MQTT every 5000000uS
if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
//then publish
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
TimePastPublish = esp_timer_get_time(); // get next publish time
}// end fDoMoistureDetector()
Important to not set vTaskDelay to less then 10. Errors begin to develop with the MQTT and network connection.
makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
const TickType_t xFrequency = 250; // 250mS
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
MQTTclient.loop();
else {
log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelete ( NULL );
void connectToMQTT()
// create client ID from mac address
byte mac[5];
int count = 0;
WiFi.macAddress(mac); // get mac address
String clientID = String(mac[0]) + String(mac[4]);
log_i( "connect to mqtt as client %s", clientID );
MQTTclient.disconnect();
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
vTaskDelay( 250 );
count++;
if ( count == 5 )
ESP.restart();
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe( topicOK );
void connectToWiFi()
int TryCount = 0;
while ( WiFi.status() != WL_CONNECTED )
TryCount++;
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
vTaskDelay( 4000 );
if ( TryCount == 10 )
ESP.restart();
WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void loop() {}
Much thanks for all the replies! Your responses have given me many options to consider. This is exactly the info that I was looking for. Will post back once I settle on a final design.
I would go with a peristaltic pump, if available. These have very precise flow rates which are largely independent of supply pressure, and a well-characterized flow rate might be important in the context of a remote watering system.
It would be nice to interface this to a soil moisture sensor, but some caution is advisable. Some sort of failsafe mechanism should be present to prevent water mishaps in the event of a sensor failure.
S.
