can someone please help, what's wrong with this code when i upload this down button sends signal continuously and the loop is not working when i select wire length stepper motor should run longer to maintain wire length and servo motor also should delay in its operation but it is running after every one second.
01_wire_cutter.ino (4.8 KB)
//------------------------------- librarys ----------------------------------
#include <Wire.h>
#include <LiquidCrystal.h>
#include <Servo.h>
//------------------------------- lcd ----------------------------------
LiquidCrystal lcd(12, 11, 2, 3, 4, 5);
//------------------------------- stepper ----------------------------------
#define stepPin 7
#define dirPin 8
//------------------------------- servo ----------------------------------
Servo snippers;
#define servo 10
#define openAngle 180
#define closedAngle 0
//------------------------------- input ----------------------------------
#define leftButton 14
#define rightButton 9
#define upButton 6
#define downButton 15
//------------------------------- user settings ----------------------------------
unsigned int wireLength = 0;
unsigned int wireQuantity = 0;
//------------------------------- system settings ----------------------------------
int state = 0;
int incrementSpeed = 1;
int previousWireLength = 0;
int previousWireQuantity = 0;
float mmPerStep = 0.18096;
lcd.begin(16, 2); //LCD columns and rows
pinMode(upButton, INPUT_PULLUP);
pinMode(downButton, INPUT_PULLUP);
pinMode(leftButton, INPUT_PULLUP);
pinMode(rightButton, INPUT_PULLUP);
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
snippers.attach(servo);
snippers.write(openAngle);
if (!digitalRead(rightButton)){
if(state == 5){
state = 0;
else{
state += 1;
delay(200);
lcd.clear();
if (!digitalRead(leftButton) && state > 0 && state < 4){
state -=1;
delay(200);
lcd.clear();
switch (state){
case 0:
homeScreen();
case 1:
chooseWireLength();
case 2:
chooseWireQuantity();
case 3:
confirm();
case 4:
currentlyCutting();
case 5:
finishedCutting();
void homeScreen(){
lcd.setCursor(0, 0);
lcd.print("WIRE CUTTER");
lcd.setCursor(11, 1);
lcd.print("NEXT>");
delay(100);
void chooseWireLength(){
wireLength = changeValue(wireLength);
//clear LCD if required
if(previousWireLength != wireLength){
lcd.clear();
previousWireLength = wireLength;
//Display information on LCD
lcd.print("LENGTH:" + (String)wireLength + "mm");
displayNavigation();
void chooseWireQuantity(){
wireQuantity = changeValue(wireQuantity);
if(previousWireQuantity != wireQuantity){
lcd.clear();
previousWireQuantity = wireQuantity;
lcd.print("QUANTITY:" + (String)wireQuantity);
void confirm(){
lcd.print((String)wireLength + "mm x " + (String)wireQuantity + "pcs");
lcd.setCursor(0, 1);
lcd.print("<BACK");
lcd.setCursor(10, 1);
lcd.print("START>");
delay(100);
void currentlyCutting(){
lcd.print((String)0 + "/" + (String)wireQuantity);
lcd.print("???s");
int stepsToTake = (int)wireLength/mmPerStep;
for(int i = 0; i < wireQuantity; i++){
unsigned long timeForOneCycle = millis();
digitalWrite(dirPin,HIGH);
for(int x = 0; x < stepsToTake; x++) {
digitalWrite(stepPin,HIGH);
delayMicroseconds(500);
digitalWrite(stepPin,LOW);
lcd.print((String)(i+1) + "/" + (String)wireQuantity);
snippers.write(closedAngle);
delay(600);
delay(600);
unsigned long timeRemaining = ((millis() - timeForOneCycle)*(wireQuantity - (i+1)))/1000;
lcd.print((String)timeRemaining + "s");
wireLength = 0;
wireQuantity = 0;
state = 5;
void finishedCutting(){
lcd.clear();
lcd.print("CUTTING COMPLETE");
lcd.print("NEXT>");
delay(100);
int changeValue(int currentValue ){
if (!digitalRead(upButton)) {
delay(100);
currentValue += incrementSpeed;
incrementSpeed++:
if (!digitalRead(downButton)) {
if(currentValue - incrementSpeed >= 0){
delay(100);
currentValue -= incrementSpeed;
else{
currentValue = 0;
if (!digitalRead(downButton) && !digitalRead(upButton)){
incrementSpeed = 1;
return currentValue;
void displayNavigation(){
lcd.print("<BACK");
lcd.print("NEXT>");
delay(100);
Preformatted text
