Hello all,
I am new to the forum and I am writing for help as I am trying to implement my first project while getting familiar with all the options offered by Arduino. The project is rather simple: keeping the humidity inside a closed box in a desired range by operating feedback on an air humidity sensor and using an existing humidifier.
The point unclear to me is the best way to automate the humidifier, which is manually activated by pressing a button.
The first idea that I had was to use a small push/pull solenoid to press the button (for example Mini Push-Pull Solenoid - 5V : ID 2776 : $4.95 : Adafruit Industries, Unique & fun DIY electronics and kits). The drawback is that tis solution requires very precise positioning and any small movement might render the system unusable.
Then I saw this video How to make your Arduino push some buttons! - Tutorial - YouTube on how to make Arduino switch on and off an external device by interacting directly with its inner circuitry. This seems a much more robust approach, but in my case the difficulty is that the humidifier does not have a simple on-off switch, but a button that selects different operating modes in round robin:
- one press activates the humidifier for 1 hour (state 1)
- the second press activates it for 3 hours (state 2)
- the third press activates it for 6 hours (state 3)
- the fourth press activates it with no time limits (state 4)
- the fifth press switches the system off (state 0)
Ideally, I would like to operate the system only between state 0 and state 4. In practice any of the on states would work as well because I do not envision having ever to run the system for more than one hour to make it stay in range. I would like however not having to worry about the timer and what signal it is expecting to receive, but just use one on/off signal. I am not very experienced with electronics switches so I am looking for some advice on how to wire the Arduino board with the device circuitry.
Operations of the button (and of other two buttons which control led color and intensity of the humidification and in which I am not interested) are processed by a small board connected to the main board of the humidifier by 6 wires. The wires (or pins) are labeled
- ground
- fog key
- led key
- pwr key
- no time
- com
The table below shows the measured voltage of every pin (with respect to pin 1) after each press of the button
Can I conclude from this table that to switch the humidifier on and off I just need to toggle pin 5 between 5V and ground or is it too simplistic? In other words, are the 5V on pin 5 a result of the switch configuration and cannot be imposed from outside?
By accident, as I was measuring continuity between the pins with a multimeter having forgotten to unplug the humidifier from the wall, I discovered that touching pin 4 with the black probe and pin 5 with the red probe produces the same effect as a button press. In other words, keeping the black probe on pin 4 and making intermittent contact with the red probe on pin 5 (and with the multimeter in continuity mode) after 5 contacts the system goes exactly through the same sequence of states as by pressing the button. While this has all the appearance of a a-ha moment, I am not sure I understand what the a-ha is because I do not know what a multimeter does when it attempts to assess continuity between two pins that are at different voltages. From what I read, it appears that the multimeter tries to establish a flux of current from the red probe to the black probe. If that was the case, to establish that flux it has to overcome a negative voltage of -0.7V to go from state 0 to state 1, from state 1 to state 2 and from state 2 to state3, then it needs to overcome a negative voltage of -5V to go from state 3 to state 4 and finally it operates with a favorable voltage of 4.3V. when it produces a transition from state 4 to state 0. I do not understand how it can always determine a transition in such different circumstances.
Does this make any sense for someone more familiar with these electronic switches? Does it suggest how to operate the switch with Arduino?
Sorry if all this sounds rather confusing, as indeed it is such for me.
