I'm an artisan (retired mech engineer)playing around with an Arduino Uno the past few weeks, for the first time, to automate a wooden Automata project I'm building. Getting frustrated! I get the basics, but having trouble to assemble tasks together easily. The project is a few simple steps;
1 start a motor (Motor1)
2 move a servo to a position and hold
3 start another motor to move a platform up (usingL298) and then hold
4 servo sweep several servos back and forth and then stop
5 start motor above in reverse to lower platform (again through L298)
6 move the servo in item 2 back to original position
7 stop (Motor1)
I would like the whole thing to start from a external pushbutton, and have thought that using an external latch relay to restart/stop the Arduino at each press might be necessary.
Anyway, look for for suggestions for a simple solution. There is so much info out there!
And I suggest looking at Planning and Implementing a Program because it will be much easier to implement your project if you treat it as a series of separate pieces.
I reckon you should manage your program as a series of transitions from one state to another. For example
Thanks for the reply. I've been attempting to follow "Several Things at One Time" because it seemed to make good sense, however I seem to get screwed up with initiating the update loops. I'll keep at this plan though. Thanks.
