Automation problems
I Trying to sort out some code from a project I’m working on to activate servos and send a signal to an ssr when they receive a change in state from a ACS712 Hall effect sensor. I’ve got the code from github but I’m having trouble reading the sensors.
I’ve checked the sensors through a separate code and know they are working but cannot get the sensors to trigger the servo or relay with this code. I’ve tried all the digital and analog read pins but can’t see the sensors reading any amp change from the sensors, although I only have 2 connected at the moment.
Can anyone help?
Please be kind as I am a noob to Arduino and programming
 * This code is for the project at
 * http://www.iliketomakestuff.com/how-to-automate-a-dust-collection-system-arduino
 * All of the components are list on the url above.
This script was created by Bob Clagett for I Like To Make Stuff
For more projects, check out iliketomakestuff.com
Includes Modified version of "Measuring AC Current Using ACS712"
https://web.archive.org/web/20190928042820/http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/acs712-arduino-ac-current-tutorial/
Parts of this sketch were taken from the keypad and servo sample sketches that comes with the keypad and servo libraries.
Uses https://github.com/adafruit/Adafruit-PWM-Servo-Driver-Library
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
// our servo # counter
uint8_t servoCount = 6;
uint8_t servonum = 0;
const int OPEN_ALL = 100;
const int CLOSE_ALL = 99;
boolean buttonTriggered = 0;
boolean powerDetected = 0;
boolean collectorIsOn = 0;
int DC_spindown = 3000;
const int NUMBER_OF_TOOLS = 3;
const int NUMBER_OF_GATES = 6;
String tools[NUMBER_OF_TOOLS] = {"Miter Saw","Table Saw","Band Saw"}; //, "Floor Sweep"
int voltSensor[NUMBER_OF_TOOLS] = {A1,A2,A3};
long int voltBaseline[NUMBER_OF_TOOLS] = {0,0,0};
//DC right, Y, miter, bandsaw, saw Y, tablesaw, floor sweep
//Set the throw of each gate separately, if needed
int gateMinMax[NUMBER_OF_GATES][2] = {
  /*open, close*/
  {250,415},//DC right
  {230,405},//Y
  {230,405},//miter
  {285,425},//bandsaw
  {250,405},//saw y
  {250,415},//floor sweep
//keep track of gates to be toggled ON/OFF for each tool
int gates[NUMBER_OF_TOOLS][NUMBER_OF_GATES] = {
  {1,0,1,0,0,0},
  {1,1,0,0,1,1},
  {1,1,0,1,0,0},
const int dustCollectionRelayPin = 11;
const int manualSwitchPin = 12; //for button activated gate, currently NOT implemented
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
double ampThreshold = .20;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
//button debouncing
int state = HIGH;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = LOW;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
void setup(){
  pinMode(dustCollectionRelayPin,OUTPUT);
  pwm.begin();
  pwm.setPWMFreq(60);  // Default is 1000mS
 //record baseline sensor settings
 //currently unused, but could be used for voltage comparison if need be.
  for(int i=0;i<NUMBER_OF_TOOLS;i++){
    pinMode(voltSensor[i],INPUT);
    voltBaseline[i] = analogRead(voltSensor[i]);
void loop(){
  // use later for button debouncing
  reading = digitalRead(manualSwitchPin);
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
    if (state == HIGH){
      state = LOW;
     buttonTriggered = false;
    } else{
      state = HIGH;
     buttonTriggered = true;
    time = millis();
  previous = reading;
   Serial.println("----------");
   //loop through tools and check
   int activeTool = 50;// a number that will never happen
      if( checkForAmperageChange(i)){
        activeTool = i;
        exit;
      if( i!=0){
        if(checkForAmperageChange(0)){
          activeTool = 0;
          exit;
  if(activeTool != 50){
    // use activeTool for gate processing
    if(collectorIsOn == false){
      //manage all gate positions
      for(int s=0;s<NUMBER_OF_GATES;s++){
        int pos = gates[activeTool][s];
        if(pos == 1){
          openGate(s);
          closeGate(s);
      turnOnDustCollection();
  } else{
    if(collectorIsOn == true){
        delay(DC_spindown);
      turnOffDustCollection();
boolean checkForAmperageChange(int which){
   Voltage = getVPP(voltSensor[which]);
   VRMS = (Voltage/2.0) *0.707;
   AmpsRMS = (VRMS * 1000)/mVperAmp;
   Serial.print(tools[which]+": ");
   Serial.print(AmpsRMS);
   Serial.println(" Amps RMS");
   if(AmpsRMS>ampThreshold){
    return true;
   }else{
    return false;
void turnOnDustCollection(){
  Serial.println("turnOnDustCollection");
  digitalWrite(dustCollectionRelayPin,1);
  collectorIsOn = true;
void turnOffDustCollection(){
  Serial.println("turnOffDustCollection");
  digitalWrite(dustCollectionRelayPin,0);
  collectorIsOn = false;
float getVPP(int sensor)
  float result;
  int readValue;             //value read from the sensor
  int maxValue = 0;          // store max value here
  int minValue = 1024;          // store min value here
   uint32_t start_time = millis();
   while((millis()-start_time) < 500) //sample for 1 Sec
       readValue = analogRead(sensor);
       // see if you have a new maxValue
       if (readValue > maxValue)
           /*record the maximum sensor value*/
           maxValue = readValue;
       if (readValue < minValue)
           minValue = readValue;
   // Subtract min from max
   result = ((maxValue - minValue) * 5.0)/1024.0;
   return result;
void closeGate(uint8_t num){
  Serial.print("closeGate ");
  Serial.println(num);
  pwm.setPWM(num, 0, gateMinMax[num][1]);
void openGate(uint8_t num){
  Serial.print("openGate ");
    pwm.setPWM(num, 0, gateMinMax[num][0]);
    delay(100);
    pwm.setPWM(num, 0, gateMinMax[num][0]-5);
Are you using the ACS712 hall sensors to measure the mains current?
If so, don't. Get some proper mains rated current transformers.
I’m using the acs712 to just detect a spike in current, it is not necessary to monitor the mains power here, just if equipment is turned on or off
RobAtha:
It's highly unlikely that the board you are using has been designed to safely isolate mains voltages from the Arduino side.
So can you recommend a sensor that I could use, I’m quite new to this but willing to work though to achieve my goals. Are there any useful references?
I've seen that code posted here before, fairly recently. I can't find my post on the topic but I think those two exit statements were intended to be break. Exit does nothing on an Arduino.
Can you post the code that showed the sensors working?
RobAtha:
https://learn.openenergymonitor.org/electricity-monitoring/ct-sensors/introduction
The 4th option on the left gives you a shopping list of components.
Thanks for he info mikb. Will have to look into this.
wildbill:
I don’t know about other posts as I’m completely new to this although I know the video on YouTube has attracted a lot of attention recently.
The website it links to is this project I like to make stuff
And the code is stored on Github
My knowledge of Arduino programming is only just starting so I’m not quite sure what you mean with the exit stuff
Earlier, you said:
I've checked the sensors through a separate code and know they are working
I'd be curious to see that code so we can see how it varies from the code you posted that isn't working.
wildbill:
Do you man the code I used to test the sensors?
I think it was just I just used a simple code from Robojax, but I will post this code here and the sensor test code when I get home
Hi Bill
As requested, here are the files i have been using,
The Robojax file is what I used to test the sensors, and obviously the dust collection V2 is the code above, Ive also included the Dust collector V1 file which it is based from which is the keypad To Servo file.
Thanks
Robojax_ACS712.ino (2.14 KB)
DustCollectionAutomation_v2.ino (6.29 KB)
keypadToServo.ino (3.7 KB)
It seems to me that your dust collection code and the Robojax code are at their root the same. They read the voltage from the current (or Hall) sensor and use it to determine whether current is flowing.
There's a lot of pointless math turning the analogRead result into Volts and Amps, and the dust code looks for maximums, which is probably good, but you can work with the raw data.
I suggest that you just write something that reads an analog input continuously and sends the result to serial. Run it when the tool it's tracking is on and run it when it's off. I expect you'll find that the pattern is very different and likely you'll see bigger values or bigger variation when the tool is running. You should be able to use that information to create something to replace checkForAmperageChange.
