TomGeorge:
S2 FUNCTION is ORed with S1 FUNCTION .
Exactly. ;D
TomGeorge:
R2a may need to be much lower in value to turn Q4 ON. Say 470R.
R4 make it 10K.
Place a 0.1uF in parallel with C1.
I was hoping for feedback on the over-voltage stuff, and I appreciate the other details you provided (I just don't have enough experience yet to spot things like this).
Additional question: I was thinking of adding another cap next to C1, but wasn't sure of value or type. From what I've seen for capturing voltage spikes, an larger electrolytic is typically paired with a smaller ceramic, so I should add a 0.1uF ceramic cap?
I'd still like to know what exactly the TVS is going to do here; i.e. specifically, what's the max voltage we'll see after it? (As I mentioned earlier, I can't make heads nor tails of the spec in this regard.) At the moment, there are far too many PMOSFETs which dislike more than 20V at their gates, so I'd like to see a maximum of 18V available after this over-voltage stuff. Will any of what's happening here meet this objective? (Doing so would eliminate the need for zeners at all of these PMOSFETs.)
TomGeorge:
Use S2 through an Opto Coupler to bias Q4 ON.
In fact would it be easier and lower component count to get S1 through another Opto to bias Q4 ON as well?
See? This is exactly why I'm here - to have the obvious (to those with more experience than me) pointed out to me. It only took two reminders for me to think of optocouplers. ![]()
Tom, thank you for all your comments.
An update to the schematics should be up soon...
Cheers!
Dirk
