Allright, since the lack of better suggestions i bought two of these:
https://www.partco.fi/fi/elektroniikan-komponentit/aktiivit/mikropiirit-listana/ic-mc/19223-mcp2515-modul.html
And modified those like this:
Connected to Wemos D1 board:
SPI connections like suggested here:
https://wiki.wemos.cc/products:d1:d1_mini
CS currently in D8, INT = D4
VCC is connected to 3.3V pin on Wemos and my added 5 volt feed for TJA1050 is coupled to 5V on Wemos
Used this library:
Despite all the effort only the loop back examples are working. "Message succsfully sent" and serial shows the data it receives.
Receive or send examples however are not working. No data is sent either received. Not in vehicle or when two of my modules are connected together.
The loopback code that works:
/* CAN Loopback Example
* This example sends a message once a second and receives that message
* no CAN bus is required. This example will test the functionality
* of the protocol controller, and connections to it.
* Written By: Cory J. Fowler - October 5th 2016
#include <mcp_can.h>
#include <SPI.h>
// CAN TX Variables
unsigned long prevTX = 0; // Variable to store last execution time
const unsigned int invlTX = 1000; // One second interval constant
byte data[] = {0xAA, 0x55, 0x01, 0x10, 0xFF, 0x12, 0x34, 0x56}; // Generic CAN data to send
// CAN RX Variables
long unsigned int rxId;
unsigned char len;
unsigned char rxBuf[8];
// Serial Output String Buffer
char msgString[128];
// CAN0 INT and CS
#define CAN0_INT D4 // Set INT to pin D4
MCP_CAN CAN0(D8); // Set CS to pin D8
Serial.begin(115200); // CAN is running at 500,000BPS; 115,200BPS is SLOW, not FAST, thus 9600 is crippling.
// Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
if(CAN0.begin(MCP_ANY, CAN_125KBPS, MCP_8MHZ) == CAN_OK)
Serial.println("MCP2515 Initialized Successfully!");
Serial.println("Error Initializing MCP2515...");
// Since we do not set NORMAL mode, we are in loopback mode by default.
//CAN0.setMode(MCP_NORMAL);
pinMode(CAN0_INT, INPUT); // Configuring pin for /INT input
Serial.println("MCP2515 Library Loopback Example...");
if(!digitalRead(CAN0_INT)) // If CAN0_INT pin is low, read receive buffer
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
if((rxId & 0x80000000) == 0x80000000) // Determine if ID is standard (11 bits) or extended (29 bits)
sprintf(msgString, "Extended ID: 0x%.8lX DLC: %1d Data:", (rxId & 0x1FFFFFFF), len);
sprintf(msgString, "Standard ID: 0x%.3lX DLC: %1d Data:", rxId, len);
Serial.print(msgString);
if((rxId & 0x40000000) == 0x40000000){ // Determine if message is a remote request frame.
sprintf(msgString, " REMOTE REQUEST FRAME");
for(byte i = 0; i<len; i++){
sprintf(msgString, " 0x%.2X", rxBuf[i]);
if(millis() - prevTX >= invlTX){ // Send this at a one second interval.
prevTX = millis();
byte sndStat = CAN0.sendMsgBuf(0x100, 8, data);
if(sndStat == CAN_OK)
Serial.println("Message Sent Successfully!");
Serial.println("Error Sending Message...");
END FILE
Any thoughts what i'm doing wrong?
