I tried the MFRC522 DumpInfo example, I able to upload the code to arduino.
From the serial monitor, it able to see Scan PICC to see UID, SAK, type, and data blocks...
Also please, please never ever again post pictures of text... Not only they are not readable nor usable directly for copy&paste but they use up lots of storage and internet bandwidth which contributes to polluting the planet. (Just copy and paste the text within code tags for example)
Yes. Just poking the pins through the holes on the PCB does not make a good connection. For the right-angle pins you have, you would usually put the short ends through the board and solder them. The longer ends would be sticking out on the end of the board.
Rather than plugging the male pins into a breadboard and using male-to-male wires, you could eliminate the breadboard by using female-to-male wires.
Thank you for your response. It works for me. My RFID able to read the data now. Really appreciate it.
However, I'm facing another issue. I was trying to complete my project with RFID Attendance Tracker. I want to upload my data to Adafruit using NodeMCU.
Not sure why when i run codes for NodeMCU, it has this error.
Can you help me with this?
Error code:
Traceback (most recent call last):
File "/Users/patricktan/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial/serial/serialposix.py", line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
OSError: [Errno 16] Resource busy: '/dev/cu.wchusbserial130'
During handling of the above exception, another exception occurred:
File "/Users/patricktan/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/upload.py", line 66, in
esptool.main(cmdline)
File "/Users/patricktan/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 3551, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "/Users/patricktan/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 271, in init
self._port = serial.serial_for_url(port)
File "/Users/patricktan/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial/serial/init.py", line 90, in serial_for_url
instance.open()
File "/Users/patricktan/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/pyserial/serial/serialposix.py", line 325, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 16] could not open port /dev/cu.wchusbserial130: [Errno 16] Resource busy: '/dev/cu.wchusbserial130'
Failed uploading: uploading error: exit status 1
