Hello everyone,
i'm having trouble with my arduino nano every board that i just recently curchased.
The first time i plugged it in and wanted to run bare minimum to test it, the code down below popped up.
What does that mean? Do i need to install a new 'programmer'?
And does anybody know why it doesn't work from the beginning, if it supposed to be a brand new product.
I already purchased a second one for comparison but the same problem accurs...
I use the correct port, board and one of these blue coding cables.
Help would be highly apprechiated!
avrdude: Can't find programmer id "jtag2updi"
Valid programmers are:
2232HIO = FT2232H based generic programmer
4232h = FT4232H based generic programmer
89isp = Atmel at89isp cable
abcmini = ABCmini Board, aka Dick Smith HOTCHIP
alf = Nightshade ALF-PgmAVR, http://nightshade.homeip.net/
arduino = Arduino
arduino-ft232r = Arduino: FT232R connected to ISP
arduinoisp = Arduino ISP Programmer
arduinoisporg = Arduino ISP Programmer
atisp = AT-ISP V1.1 programming cable for AVR-SDK1 from <http://micro-research.co.th/>
atmelice = Atmel-ICE (ARM/AVR) in JTAG mode
atmelice_dw = Atmel-ICE (ARM/AVR) in debugWIRE mode
atmelice_isp = Atmel-ICE (ARM/AVR) in ISP mode
atmelice_pdi = Atmel-ICE (ARM/AVR) in PDI mode
avr109 = Atmel AppNote AVR109 Boot Loader
avr910 = Atmel Low Cost Serial Programmer
avr911 = Atmel AppNote AVR911 AVROSP
avrftdi = FT2232D based generic programmer
avrisp = Atmel AVR ISP
avrisp2 = Atmel AVR ISP mkII
avrispmkII = Atmel AVR ISP mkII
avrispv2 = Atmel AVR ISP V2
bascom = Bascom SAMPLE programming cable
blaster = Altera ByteBlaster
bsd = Brian Dean's Programmer, http://www.bsdhome.com/avrdude/
buspirate = The Bus Pirate
buspirate_bb = The Bus Pirate (bitbang interface, supports TPI)
butterfly = Atmel Butterfly Development Board
butterfly_mk = Mikrokopter.de Butterfly
bwmega = BitWizard ftdi_atmega builtin programmer
C232HM = FT232H based module from FTDI and Glyn.com.au
c2n232i = serial port banging, reset=dtr sck=!rts mosi=!txd miso=!cts
dapa = Direct AVR Parallel Access cable
dasa = serial port banging, reset=rts sck=dtr mosi=txd miso=cts
dasa3 = serial port banging, reset=!dtr sck=rts mosi=txd miso=cts
diecimila = alias for arduino-ft232r
dragon_dw = Atmel AVR Dragon in debugWire mode
dragon_hvsp = Atmel AVR Dragon in HVSP mode
dragon_isp = Atmel AVR Dragon in ISP mode
dragon_jtag = Atmel AVR Dragon in JTAG mode
dragon_pdi = Atmel AVR Dragon in PDI mode
dragon_pp = Atmel AVR Dragon in PP mode
dt006 = Dontronics DT006
ere-isp-avr = ERE ISP-AVR <http://www.ere.co.th/download/sch050713.pdf>
flip1 = FLIP USB DFU protocol version 1 (doc7618)
flip2 = FLIP USB DFU protocol version 2 (AVR4023)
frank-stk200 = Frank STK200
ft232r = FT232R Synchronous BitBang
ft245r = FT245R Synchronous BitBang
futurlec = Futurlec.com programming cable.
jtag1 = Atmel JTAG ICE (mkI)
jtag1slow = Atmel JTAG ICE (mkI)
jtag2 = Atmel JTAG ICE mkII
jtag2avr32 = Atmel JTAG ICE mkII im AVR32 mode
jtag2dw = Atmel JTAG ICE mkII in debugWire mode
jtag2fast = Atmel JTAG ICE mkII
jtag2isp = Atmel JTAG ICE mkII in ISP mode
jtag2pdi = Atmel JTAG ICE mkII PDI mode
jtag2slow = Atmel JTAG ICE mkII
jtag3 = Atmel AVR JTAGICE3 in JTAG mode
jtag3dw = Atmel AVR JTAGICE3 in debugWIRE mode
jtag3isp = Atmel AVR JTAGICE3 in ISP mode
jtag3pdi = Atmel AVR JTAGICE3 in PDI mode
jtagkey = Amontec JTAGKey, JTAGKey-Tiny and JTAGKey2
jtagmkI = Atmel JTAG ICE (mkI)
jtagmkII = Atmel JTAG ICE mkII
jtagmkII_avr32 = Atmel JTAG ICE mkII im AVR32 mode
lm3s811 = Luminary Micro LM3S811 Eval Board (Rev. A)
mib510 = Crossbow MIB510 programming board
mkbutterfly = Mikrokopter.de Butterfly
nibobee = NIBObee
o-link = O-Link, OpenJTAG from www.100ask.net
openmoko = Openmoko debug board (v3)
pavr = Jason Kyle's pAVR Serial Programmer
pickit2 = MicroChip's PICkit2 Programmer
picoweb = Picoweb Programming Cable, http://www.picoweb.net/
pony-stk200 = Pony Prog STK200
ponyser = design ponyprog serial, reset=!txd sck=rts mosi=dtr miso=cts
siprog = Lancos SI-Prog <http://www.lancos.com/siprogsch.html>
sp12 = Steve Bolt's Programmer
stk200 = STK200
stk500 = Atmel STK500
stk500hvsp = Atmel STK500 V2 in high-voltage serial programming mode
stk500pp = Atmel STK500 V2 in parallel programming mode
stk500v1 = Atmel STK500 Version 1.x firmware
stk500v2 = Atmel STK500 Version 2.x firmware
stk600 = Atmel STK600
stk600hvsp = Atmel STK600 in high-voltage serial programming mode
stk600pp = Atmel STK600 in parallel programming mode
ttl232r = FTDI TTL232R-5V with ICSP adapter
tumpa = TIAO USB Multi-Protocol Adapter
UM232H = FT232H based module from FTDI and Glyn.com.au
uncompatino = uncompatino with all pairs of pins shorted
usbasp = USBasp, http://www.fischl.de/usbasp/
usbasp-clone = Any usbasp clone with correct VID/PID
usbtiny = USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
wiring = Wiring
xil = Xilinx JTAG cable
xplainedmini = Atmel AVR XplainedMini in ISP mode
xplainedmini_dw = Atmel AVR XplainedMini in debugWIRE mode
xplainedpro = Atmel AVR XplainedPro in JTAG mode
Failed uploading: uploading error: exit status 1
That list of programmers to support is horrendous. Anyway, I just happen to have a Nano Every by me. I'm using Arduino IDE 1.8.19 and it clearly finds the programmer jtag2updi and proceeds to load and run the blink sketch.
Which IDE version are you using ?
Sketch uses 1118 bytes (2%) of program storage space. Maximum is 49152 bytes.
Global variables use 22 bytes (0%) of dynamic memory, leaving 6122 bytes for local variables. Maximum is 6144 bytes.
Forcing reset using 1200bps open/close on port COM8
C:\Users\6v6gt\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\6v6gt\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega4809 -cjtag2updi -PCOM8 -b115200 -e -D -Uflash:w:C:\Users\6v6gt\AppData\Local\Temp\arduino_build_781756/Blink.ino.hex:i -Ufuse2:w:0x01:m -Ufuse5:w:0xC9:m -Ufuse8:w:0x00:m {upload.extra_files}
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\6v6gt\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM8
Using Programmer : jtag2updi
Overriding Baud Rate : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
boot-loader FW version: 1
firmware version: 6.00
hardware version: 1
S_MCU:
hardware version: 1
And maybe check in the Boards Manager that you have a reasonably new version of the Arduino MegaAVR Boards:
I am using the newest 2.0 version but also tried it out on the 1.8.19 version.
Same problem, same code....
Maybe i can manually install the programmer in the right folder?
I already tried reinstalling the program, without any success.
Maybe i just didnt get rid of everything?
Note that i have my library and sketch files in a different place in my computer.
Maybe it has something to do with that?
Thjo i never had any issues with my Uno regarding that...
I upload via. micro USB cable to my Nano Every.
Thats why im a little confused. I thought the Nano Every had a integrated programmer.
In Preferences have you checked verbose output during upload, and that is what you posted?
I now checkmarked the upload option and the same code with a data path comes up after trying to upload.
What do you have where?
Only the downloaded libraries like IRremote, used for programming different modules. i figured it would not impact my problem. Also sketches of past projects, nothing else. Just pretty irrelevant stuff imo.
System wide configuration file is "C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
2232HIO = FT2232H based generic programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:412]
4232h = FT4232H based generic programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:440]
89isp = Atmel at89isp cable [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1387]
abcmini = ABCmini Board, aka Dick Smith HOTCHIP [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1286]
alf = Nightshade ALF-PgmAVR, http://nightshade.homeip.net/ [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1246]
arduino = Arduino [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:360]
arduino-ft232r = Arduino: FT232R connected to ISP [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:764]
arduinoisp = Arduino ISP Programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:878]
arduinoisporg = Arduino ISP Programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:887]
atisp = AT-ISP V1.1 programming cable for AVR-SDK1 from <http://micro-research.co.th/> [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1342]
atmelice = Atmel-ICE (ARM/AVR) in JTAG mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1132]
atmelice_dw = Atmel-ICE (ARM/AVR) in debugWIRE mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1148]
atmelice_isp = Atmel-ICE (ARM/AVR) in ISP mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1156]
atmelice_pdi = Atmel-ICE (ARM/AVR) in PDI mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1140]
avr109 = Atmel AppNote AVR109 Boot Loader [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:903]
avr910 = Atmel Low Cost Serial Programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:721]
avr911 = Atmel AppNote AVR911 AVROSP [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:910]
avrftdi = FT2232D based generic programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:386]
avrisp = Atmel AVR ISP [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:608]
avrisp2 = Atmel AVR ISP mkII [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:628]
avrispmkII = Atmel AVR ISP mkII [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:622]
avrispv2 = Atmel AVR ISP V2 [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:615]
bascom = Bascom SAMPLE programming cable [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1240]
blaster = Altera ByteBlaster [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1364]
bsd = Brian Dean's Programmer, http://www.bsdhome.com/avrdude/ [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1195]
buspirate = The Bus Pirate [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:633]
buspirate_bb = The Bus Pirate (bitbang interface, supports TPI) [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:640]
butterfly = Atmel Butterfly Development Board [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:896]
butterfly_mk = Mikrokopter.de Butterfly [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:924]
bwmega = BitWizard ftdi_atmega builtin programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:751]
C232HM = FT232H based module from FTDI and Glyn.com.au [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:509]
c2n232i = serial port banging, reset=dtr sck=!rts mosi=!txd miso=!cts [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1492]
dapa = Direct AVR Parallel Access cable [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1330]
dasa = serial port banging, reset=rts sck=dtr mosi=txd miso=cts [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1464]
dasa3 = serial port banging, reset=!dtr sck=rts mosi=txd miso=cts [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1478]
diecimila = alias for arduino-ft232r [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:775]
dragon_dw = Atmel AVR Dragon in debugWire mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1059]
dragon_hvsp = Atmel AVR Dragon in HVSP mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1050]
dragon_isp = Atmel AVR Dragon in ISP mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1032]
dragon_jtag = Atmel AVR Dragon in JTAG mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1023]
dragon_pdi = Atmel AVR Dragon in PDI mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1068]
dragon_pp = Atmel AVR Dragon in PP mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1041]
dt006 = Dontronics DT006 [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1230]
ere-isp-avr = ERE ISP-AVR <http://www.ere.co.th/download/sch050713.pdf> [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1353]
flip1 = FLIP USB DFU protocol version 1 (doc7618) [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1179]
flip2 = FLIP USB DFU protocol version 2 (AVR4023) [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1186]
frank-stk200 = Frank STK200 [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1377]
ft232r = FT232R Synchronous BitBang [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:739]
ft245r = FT245R Synchronous BitBang [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:728]
futurlec = Futurlec.com programming cable. [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1297]
jtag1 = Atmel JTAG ICE (mkI) [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:937]
jtag1slow = Atmel JTAG ICE (mkI) [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:942]
jtag2 = Atmel JTAG ICE mkII [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:972]
jtag2avr32 = Atmel JTAG ICE mkII im AVR32 mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1005]
jtag2dw = Atmel JTAG ICE mkII in debugWire mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:987]
jtag2fast = Atmel JTAG ICE mkII [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:966]
jtag2isp = Atmel JTAG ICE mkII in ISP mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:978]
jtag2pdi = Atmel JTAG ICE mkII PDI mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1014]
jtag2slow = Atmel JTAG ICE mkII [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:961]
jtag3 = Atmel AVR JTAGICE3 in JTAG mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1076]
jtag3dw = Atmel AVR JTAGICE3 in debugWIRE mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1092]
jtag3isp = Atmel AVR JTAGICE3 in ISP mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1100]
jtag3pdi = Atmel AVR JTAGICE3 in PDI mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1084]
jtagkey = Amontec JTAGKey, JTAGKey-Tiny and JTAGKey2 [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:447]
jtagmkI = Atmel JTAG ICE (mkI) [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:929]
jtagmkII = Atmel JTAG ICE mkII [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:953]
jtagmkII_avr32 = Atmel JTAG ICE mkII im AVR32 mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:996]
lm3s811 = Luminary Micro LM3S811 Eval Board (Rev. A) [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:570]
mib510 = Crossbow MIB510 programming board [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:672]
mkbutterfly = Mikrokopter.de Butterfly [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:918]
nibobee = NIBObee [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:847]
o-link = O-Link, OpenJTAG from www.100ask.net [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:541]
openmoko = Openmoko debug board (v3) [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:552]
pavr = Jason Kyle's pAVR Serial Programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1165]
pickit2 = MicroChip's PICkit2 Programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1172]
picoweb = Picoweb Programming Cable, http://www.picoweb.net/ [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1275]
pony-stk200 = Pony Prog STK200 [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1223]
ponyser = design ponyprog serial, reset=!txd sck=rts mosi=dtr miso=cts [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1442]
siprog = Lancos SI-Prog <http://www.lancos.com/siprogsch.html> [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1455]
sp12 = Steve Bolt's Programmer [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1263]
stk200 = STK200 [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1207]
stk500 = Atmel STK500 [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:658]
stk500hvsp = Atmel STK500 V2 in high-voltage serial programming mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:693]
stk500pp = Atmel STK500 V2 in parallel programming mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:686]
stk500v1 = Atmel STK500 Version 1.x firmware [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:665]
stk500v2 = Atmel STK500 Version 2.x firmware [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:679]
stk600 = Atmel STK600 [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:700]
stk600hvsp = Atmel STK600 in high-voltage serial programming mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:714]
stk600pp = Atmel STK600 in parallel programming mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:707]
ttl232r = FTDI TTL232R-5V with ICSP adapter [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:811]
tumpa = TIAO USB Multi-Protocol Adapter [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:591]
UM232H = FT232H based module from FTDI and Glyn.com.au [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:482]
uncompatino = uncompatino with all pairs of pins shorted [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:787]
usbasp = USBasp, http://www.fischl.de/usbasp/ [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:822]
usbasp-clone = Any usbasp clone with correct VID/PID [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:858]
usbtiny = USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/ [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:869]
wiring = Wiring [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:353]
xil = Xilinx JTAG cable [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1316]
xplainedmini = Atmel AVR XplainedMini in ISP mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1116]
xplainedmini_dw = Atmel AVR XplainedMini in debugWIRE mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1124]
xplainedpro = Atmel AVR XplainedPro in JTAG mode [C:\Users\Polle\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1108]
Very strange.
The avrdude path looks the same as mine.
System wide configuration file is "C:\Users\Richard\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
You have not posted the verbose output from compile, but is your megaavr core also in Arduino 15?
Using board 'nona4809' from platform in folder: C:\Users\Richard\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7
its the exact same as yours, also a 1.8.7 with many files inside.
Im starting to think that the files are ok and im doing something very obvious wrong...
Take a look inside my 1.8.7 folder:
Another thing that i realized: Im using a single port from my notebook.
My old EELEGO Uno was connected to port COM3
For my Nano Every it detects COM6
and for my new Arduino Uno (At least thats working correctly) COM5
Is that normal? Maybe my notebook is the cause of my problem?
I suppose you could also try going into the "Boards Manager", uninstalling the "Arduino megaAVR Boards" entry which supports the Nano Every etc., restarting the PC and then again reinstalling the "Arduino megaAVR Boards" entry. Tell us also which version of "Arduino megaAVR Boards" is installed. The screen shot in post #2 is NOT the latest.
