Cant upload code to nan every
these are the messages im recieving:avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
avrdude: jtagmkII_reset(): timeout/error communicating with programmer (status -1)
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: jtagmkII_close(): timeout/error communicating with programmer (status -1)
Failed uploading: uploading error: exit status 1
avrdude: usbhid_open(): No device found
avrdude: jtag3_open_common(): Did not find any device matching VID 0x03eb and PID list: 0x2145
Failed to burn bootloader: uploading error: exit status avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
TL;DR:
is often a spurious warning (not an error) which can be safely ignored.
That much of it you can ignore. The timeout/error on the other hand, that's a real problem.
That makes it sound like it can't find the Nano Every. Does the cable check out? What O/S are you using?
The Nano series consists of many boards with different processors, and there are clones from other manufacturers. So: triple check that the board you selected in the IDE is indeed the board you have.
You showed only part of the output of the IDE, not the part that should have said: Using Programmer : jtag2updi when uploading to an Arduino Nano Every.
As soon as I read your note a lightbulb went on.
The OP's partial error message included the VID & PID, and they're not for the Nano Every. They're for the Uno WiFi Rev2. The Nano Every is 2341:0058, and the Uno WiFi Rev2 is 03eb:2145.
Uploading to Nano Every with setting Uno Wifi Rev2 did not exactly reproduce the error in post#1, but did confirm VID 0x03eb and PID 0x2145 for Uno Wifi Rev2.
when i look at my programmer settings the obly one that shows is onboard atml mEDBG UNO WIFI Rev2
where can i find the Nano Every 2341:0058
these are the settings i have now but 10min pass and it still says uploading now
Why are you specifying a programmer?
Does your IDE have the correct board selected:
IDE >> TOOLS >> BOARDS >> AVR BOARDS >> your board
Which function did you use to upload the code to the board?
Why did you selected Uno Wifi programmer (as on photo) ?
i didnt choose the uno wifi programmer. its the only option that shows up. if i dont click on the programmer it stays on uploading but before with the erroe codes it was because i had the wrong emulator
I have merged your cross-posts @atoral15.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
The USB bridge on the Nano Every is the same as on the Uno Wifi Rev2.
No need to look for another programmer.
I do not think that is true.
The Nano Every uses a SAMD11 chip as the usb interface, and it is put into code download mode by a 1200 bps trigger signal from the ide and runs firmware called MUXTO.
The WiFi Rev2 uses a 32u4 as the interface chip. It is switched into download mode by the 1200 bps trigger and runs mEDBG firmware.
For a Nano Every , the successful download of the blink sketch with with ide 2.3 with verbose output selected in preferences shows:
Sketch uses 1118 bytes (2%) of program storage space. Maximum is 49152 bytes.
Global variables use 22 bytes (0%) of dynamic memory, leaving 6122 bytes for local variables. Maximum is 6144 bytes.
Performing 1200-bps touch reset on serial port COM9
"C:\Users\yourName\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\yourName\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega4809 -cjtag2updi -PCOM9  -b115200 -e -D "-Uflash:w:C:\Users\yourName\AppData\Local\Temp\arduino\sketches\DA903E15D84425D10FB5497B3B858C43/Blink.ino.hex:i" "-Ufuse2:w:0x01:m" "-Ufuse5:w:0xC9:m" "-Ufuse8:w:0x00:m" {upload.extra_files}
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\yourName\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM9
         Overriding Baud Rate          : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
  boot-loader FW version:        1
  firmware version:              1.07
  hardware version:              1
S_MCU:
  firmware version:              6.07
  hardware version:              1
Serial number:                   00:00:00:00:00:00
Device ID:                       JTAGICE mkII
         AVR Part                      : ATmega4809
         Chip Erase delay              : 0 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 0
         StabDelay                     : 0
         CmdexeDelay                   : 0
         SyncLoops                     : 0
         ByteDelay                     : 0
         PollIndex                     : 0
         PollValue                     : 0x00
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           prodsig        0     0     0    0 no         61   61      0     0     0 0x00 0x00
           fuses          0     0     0    0 no          9    0      0     0     0 0x00 0x00
           fuse0          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse1          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse2          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse4          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse5          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse6          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse7          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse8          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0     0     0 0x00 0x00
           data           0     0     0    0 no          0    0      0     0     0 0x00 0x00
           usersig        0     0     0    0 no         64   64      0     0     0 0x00 0x00
           flash          0     0     0    0 no      49152  128      0     0     0 0x00 0x00
           eeprom         0     0     0    0 no        256   64      0     0     0 0x00 0x00
         Programmer Type : JTAGMKII_PDI
         Description     : JTAGv2 to UPDI bridge
         M_MCU hardware version: 1
         M_MCU firmware version: 1.07
         S_MCU hardware version: 1
         S_MCU firmware version: 6.07
         Vtarget         : 5.0 V
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.15s
avrdude: Device signature = 0x1e9651 (probably m4809)
avrdude: erasing chip
avrdude: reading input file "C:\Users\yourName\AppData\Local\Temp\arduino\sketches\DA903E15D84425D10FB5497B3B858C43/Blink.ino.hex"
avrdude: writing flash (1118 bytes):
Writing | ################################################## | 100% 0.84s
avrdude: 1118 bytes of flash written
avrdude: reading input file "0x01"
avrdude: writing fuse2 (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of fuse2 written
avrdude: reading input file "0xC9"
avrdude: writing fuse5 (1 bytes):
avrdude: 1 bytes of fuse5 written
avrdude: reading input file "0x00"
avrdude: writing fuse8 (1 bytes):
avrdude: 1 bytes of fuse8 written
avrdude done.  Thank you.
For my Nano Every I also get only 1 option for programmer: Onboard Atmal mEDBG (UNO WiFi Rev2) and it worked fine.
However, a different protocol is used:
uno2018.upload.protocol=xplainedmini_updi (for UNO WiFi Rev2)
nona4809.upload.protocol=jtag2updi (for Nano Every)
(from boards.txt)
