avrdude: stk500_recv(): programmer is not responding problem
Hi . I am new here.
When I upload my uno I get that message
Arduino: 1.8.9 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 2658 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 195 bytes (9%) of dynamic memory, leaving 1853 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x39
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
What can I do? pls help.
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino board, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
Did you load the CH340g file to your computer? Have you opened up your Device manager and looked at the com ports to see if the driver is ther and that the com port is recognized?
Another suggestion would be to try the loopback test to assure your Arduino is actually working. I have included it here for you to try, it is also available in the forum under loop back test.
Loop-Back Test Instructions...
  1. Disconnect power from the board
  2. Remove all connections and shields from the board
  3. Force the processor to remain in reset by connecting a jumper from RESET to GND
  4. Connect a jumper from the TX pin (Digital Pin 1) to the RX pin (Digital Pin 0)
  5. Connect the board to your computer. After a brief pause Windows will produce a device-insertion tone if sound is enabled. Linux may or may not produce a device-insertion tone; an entry is added to the system log.
  6. Start your favourite terminal application. Serial Monitor will work fine.
  7. Connect the terminal application to the serial port for your board. The baud rate is irrelevant.
  8. Send data by typing. Everything you type should be echoed back. To send data, some terminal applications, like Serial Monitor, require pressing the Enter key or clicking a Send button. If exactly what you send is echoed back then the board passes the test. This means that the host computer hardware driver, USB cable, and USB to serial converter are all working.
  9. Shutdown the terminal application
  10. Disconnect the board from the computer
  11. Remove the two jumpers
