I tried upload code to arduino/genuino uno, with PIC18F45K22 Microprocessor and ATmega328 Microprocessor but I received this error:
Arduino: 1.8.1 (Linux), Board: "Arduino/Genuino Uno"
Sketch uses 6210 bytes (19%) of program storage space. Maximum is 32256 bytes.
Global variables use 232 bytes (11%) of dynamic memory, leaving 1816 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I tried upload a basic code to this hardware: Bot'n Roll ONE A Robot. This board has the basic arduino embedded.
Any suggestions are welcome, thanks
I am getting this same message when I try uploading the blink program. Can anyone help. I have the Arduino 1.8.1 version installed on a 32bit windows 7 computer . My compute is recognizing the unit plugged into the port. But error come in the downloading process.
What does the device manager tell you, when you plug in the USB cable?
If an Arduino was detected -> did Windows allocate a COM port and did you select this COM port in the IDE?
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
Error while burning bootloader.
