Avrdude: stk500_recv(): programmer is not responding help me please
Hello, I need help.
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\PC\AppData\Local\Temp\arduino_build_170136/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM1
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd1
avrdude done.  Thank you.
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Arduino IDE's Tools > Board menu. Note that some boards have similar names, but are not interchangeable. Examples include "Arduino Uno" vs. "Arduino Uno WiFi" vs. "Arduino Uno WiFi Rev2".
Make sure you have selected the port of your Arduino board from the Arduino IDE's Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino board, you can find it by doing this:
  1. Unplug your Arduino board from the computer.
  2. Select Tools > Port from the Arduino IDE's menus.
  3. Note the ports, if any, listed in the menu.
  4. Close the Tools menu.
    The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Plug your Arduino board into the computer.
  6. Select Tools > Port from the Arduino IDE's menus. - The new port listed in the menu is the one for your Arduino board.
