Avrdude timeout error during upload
This is my first time using an arduino. I followed this guide to install the ide: https://docs.arduino.cc/software/ide-v1/tutorials/Linux
My board is a Feather M0 WiFi so I am using the 'M0' board when I try to upload.
I am getting the following error repeated several times when I try to upload a sketch:
avrdude: stk500v2_ReceiveMessage(): timeout
I have so far tried:
  • adding dialout permission to my user
  • installing avrdude manually
  • running the arduino ide as root
  • clicking and double-clicking the reset button after starting an upload
  • reinstalling my operating system (Ubuntu 20.04)
When I add the verbose option in the ide I get the following:
Picked up JAVA_TOOL_OPTIONS:
Sketch uses 11692 bytes (4%) of program storage space. Maximum is 262144 bytes.
Global variables use 2980 bytes (9%) of dynamic memory, leaving 29788 bytes for local variables. Maximum is 32768 bytes.
Forcing reset using 1200bps open/close on port /dev/ttyACM0
PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {}
Uploading using selected port: /dev/ttyACM0
/home/ted/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/ted/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -v -patmega2560 -cstk500v2 -P/dev/ttyACM0 -b57600 -Uflash:w:/tmp/arduino_build_127002/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/ted/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/home/ted/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 57600
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_getsync(): timeout communicating with programmer
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: Unknown
Has anybody seen this before or know how it could be fixed?
Try this link. It worked for me (Linux Mint, 32-bit and 64-bit)
Your problem is that your board is not switching to bootloader mode; the PORTS lines indicate that.
First question is if the port that you use is indeed your M0? Does it disappear if you disconnect the board?
If the port is indeed your board, you can try below.
I'm not familiar with your board. If it has a reset button, double tap it when you see the PORTS lines.
If the port is not your board, you'll have to figure out why. You might be using a charge-only cable that does not carry the USB data signals.
Thanks. I just tried this and got the same error message. I also tried it with arduino version 1.8.18, 1.8.16, and 1.0.6 and got the same error (except 1.0.6 didn't look like it had my board)
Thanks. I did not know that was part of the issue.
I am certain that the port I am using is the correct one because the 'Ports' dropdown grays out when I unplug it.
It does have a reset button. I tried double clicking it with the verbose option as you suggest and it does look like it did something but it still failed:
PORTS {/dev/ttyACM0, } / {} => {}
PORTS {} / {} => {}
PORTS {} / {/dev/ttyACM0, } => {/dev/ttyACM0, }
Found upload port: /dev/ttyACM0
/home/ted/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/ted/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -v -patmega2560 -cstk500v2 -P/dev/ttyACM0 -b57600 -Uflash:w:/tmp/arduino_build_181809/myblink.ino.hex:i
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
I have seen the PAGEL and BS2 error when using TOOLS >> BOARD >> "Arduino as ISP"... but probably you are not wanting to do that now.
OK, there is progress.
The first line is where the reset was issued and the board switched to bootloader mode. The second line is where the board is reseting and the 3rd line is where the bootloader is active.
I have no knowledge around the Feather M0 WiFi. But the use of avrdude is suspect; I think that there is a different tool to perform the upload for ARM based boards and hence I suspect that you choose the wrong board in the IDE.
What is the 'M0' board that you're referring to? Did you install the boards package for the Adafruit board? Can you provide a link to the board (on the Adafruit side).
Huzzah! Your suspicion was correct. I was using the wrong board all along apparently.
This is the board I have: Adafruit Feather M0 WiFi - ATSAMD21 + ATWINC1500 : ID 3010 : $39.95 : Adafruit Industries, Unique & fun DIY electronics and kits
I assumed it would be one of the M0 boards but none of those worked. Then reading the entire description, it says
At the Feather M0's heart is an ATSAMD21G18 ARM Cortex M0 processor, clocked at 48 MHz and at 3.3V logic, the same one used in the new Arduino Zero
I saw this and tried uploading with the Arduino Zero board, which worked. I am not sure exactly why because of the few M0 boards that I looked at it looks like they all use the same processor as the Arduino Zero, so it seems like there may be something wrong with whatever configures the format for the M0 boards.
Anyways by board is doing Blinky now so I am happy. Thanks for your help!
