Today I am using a Arduino Uno to flush my own design based on ATmega32u4. But I got the problem shows "avrdude: Yikes! Invalid device signature.".
Could some help me to solve?
The wiring refers to this:
The step I did is:
- Connect Arduino UNO, flushing with a empty sketch.
- Download ArduinoISP for Arduino UNO.
- Change board to Arduino Leonardo and select Arduino as IPS
- Burn Bootloader
and then I had problem:
Double check connections and try again, or use -F to override
this check.
Error while burning bootloader.
pert:
Please do this:
- File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
- Tools > Burn Bootloader
- After the process fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
- Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
After followed some instructions on the forum, I tired to upload an empty file before the ArduinoISP example, I burned the bootloader successfully.
Here is the information I have.
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\arduino\avr/bootloaders/caterina/Caterina-Leonardo.hex"
avrdude: writing flash (32730 bytes):
Writing | ################################################## | 100% 35.65s
avrdude: 32730 bytes of flash written
avrdude: verifying flash memory against C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\arduino\avr/bootloaders/caterina/Caterina-Leonardo.hex:
avrdude: load data flash data from input file C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\arduino\avr/bootloaders/caterina/Caterina-Leonardo.hex:
avrdude: input file C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\arduino\avr/bootloaders/caterina/Caterina-Leonardo.hex contains 32730 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 19.92s
avrdude: verifying ...
avrdude: 32730 bytes of flash verified
avrdude: reading input file "0x2F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x2F:
avrdude: load data lock data from input file 0x2F:
avrdude: input file 0x2F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock verified
avrdude done. Thank you.
But after this, I find that the PC does not recognize my board when I connected it with a Micro USB cable(This cable works well with other Leonardo boatds. So what should I do?
PCB design is shown as following:
