Hello,
I am using an axis control to detect momentary movement.
Here is the code to get the axis values
Vector raw = compass.readRaw();
xCur = raw.XAxis;
yCur = raw.YAxis;
zCur = raw.ZAxis;
the xCur is the current value of the sensor.
Then I save the last position of the sensor in order to detect movement.
void location set ()
xCal = raw.XAxis;
xMin = (xCal - tolerance);
xMax = (xCal + tolerance);
yCal = raw.YAxis;
yMin = (yCal - tolerance);
yMax = (yCal + tolerance);
zCal = raw.ZAxis;
zMin = (zCal - tolerance);
zMax = (zCal + tolerance);
The problem is that when the program exits the function and reads again the values of the sensor it always detects movement no matter whats the "tolerance" value.
Results:
location set
Xraw = -303 xMin = -383 xMax =
-223
Yraw = -63 yMin = -143 yMax = 17
Zraw = 207 zMin = 127 zMax = 287
Read Values.
raw.XAxis-354 raw.YAxis-148 raw.ZAxis80tsoup
