Here's a tilt compensated compass for the Arduino Nano 33 Rev2.
The code will be at the end of the page, but it’s important to read how you should run it.
The reason I’m sharing this is because I didn’t find one specific for this board and its IMU/Magnetometer package.
It's mostly based on the following tutorial.
I also used the following video as reference.
You should look beyond the tilt compensated compass aspect of it. I’m new to working with sensors and this project allowed me to learn a few things. If you’re new to working with accelerometers, gyroscopes and magnetometers these are the most important things you should get out of this.
1 - How to do a basic calibration of accelerometers, gyroscopes and magnetometers.
2 - How to fuse sensors together.
3 - How to filter input values.
First time usage - Calibration
Before you start, this project can run in two modes, calibration and normal mode.
The first time you run it you should run with this variable set to true:
bool calibrationModeEnabled = true;
Follow the instructions on the Serial console.
The first thing it will tell you is to put the board on a flat leveled surface and don't move it to calculate the accelerometer and gyroscope errors.
After a few seconds it will instruct you to move the board around for a while to calculate the hard iron error and soft iron scaling of the magnetometer.
Set the values provided in the Serial console on the corresponding variables.
Example
float accel_zerog[3] = { 0.0057, -0.0191, 0.0135 };
float gyro_zerorate[3] = { -0.0232, 0.1022, -0.6760 };
float mag_hardiron[3] = { -12.0, 10.0, -20.5 };
float mag_softiron[3] = { 1.0191, 0.9714, 1.0108 };
After this you can set the following variable to false and upload the program to the board again.
bool calibrationModeEnabled = false;
Now you should see the heading on the serial console. You should point the X axis of the magnetometer (inside the red rectangle) to where you want to read.
If you wish, instead of using the X axis of the magnetometer you can use the side of the board where the ublox chip is located to point to the heading by setting the following variable to false:
bool useBoardMagnetometerReferentialToPointAtHeading = false;
I hope you find this useful. If you have any doubts I encourage you the read the original tutorial and the video at the start because they do a way better job at explaining this stuff than I do.
Code
#include "Arduino_BMI270_BMM150.h"
* This is used to override the default magnetometer sampling rate.
* To change it to 30Hz go to the file Arduino\libraries\Arduino_BMI270_BMM150\src\utilities\BMM150-Sensor-API\bmm150.c
* Search for the line 825 which contains the following:
* case BMM150_PRESETMODE_HIGHACCURACY:
* Inside this case statement change the line:
* settings->data_rate = BMM150_DATA_RATE_20HZ;
* To
* settings->data_rate = BMM150_DATA_RATE_30HZ;
class MyBoschSensor : public BoschSensorClass {
public:
MyBoschSensor(TwoWire& wire = Wire)
: BoschSensorClass(wire){};
protected:
virtual int8_t configure_sensor(struct bmm150_dev* dev) override {
int8_t rslt;
struct bmm150_settings settings;
settings.pwr_mode = BMM150_POWERMODE_NORMAL;
rslt = bmm150_set_op_mode(&settings, dev);
if (rslt == BMM150_OK) {
/* Setting the preset mode as High Accuracy power mode
* i.e. data rate = 20Hz
settings.preset_mode = BMM150_PRESETMODE_HIGHACCURACY;
rslt = bmm150_set_presetmode(&settings, dev);
/* Map the data interrupt pin */
settings.int_settings.drdy_pin_en = 0x01;
//rslt = bmm150_set_sensor_settings(BMM150_SEL_DRDY_PIN_EN, &settings, dev);
return rslt;
MyBoschSensor myIMU(Wire1);
const float geoDeclinationAngle = 11.41666666666667;
//const float localMagDeclinationAngle = -0.7266666666666667;
float ax, ay, az, gx, gy, gz, mx, my, mz;
float accRoll, accPitch, accYaw, accTotalVector, gyroRoll, gyroPitch, gyroYaw, gyroPitchOutput, gyroRollOutput, magRoll, magPitch, magYaw, magXHor, magYHor, magXDampened, magYDampened;
float elapsedTime, currentTime, previousTime;
int numberOfAccelerometerAndGyroCalibrationCycles = 200;
int numberOfMagnetometerCalibrationCycles = 2000;
bool calibrateAccelerometerAndGyroOnStart = false;
bool debugEnabled = false;
// This can be used to select between the magnetometer referencial or the side of the board opposite to the USB port to point at the heading.
/* Sensor Calibration Section */
// Accelerometer calibration
float accel_zerog[3] = { 0, 0, 0 };
// Gryroscope calibration
float gyro_zerorate[3] = { 0, 0, 0 };
// Magnetometer calibration
float mag_hardiron[3] = { 0, 0, 0 };
float mag_softiron[3] = { 0, 0, 0 };
int i = 0;
while (!Serial)
Serial.println("Tilt Compensated Compass Starting...");
if (!myIMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1)
Serial.print("Magnetic field sample rate = ");
Serial.print(myIMU.magneticFieldSampleRate());
Serial.println(" Hz");
Serial.print("Accelerometer sample rate = ");
Serial.print(myIMU.accelerationSampleRate());
Serial.print("Gyrsoscope sample rate = ");
Serial.print(myIMU.gyroscopeSampleRate());
// The accelerometer and gyroscope can be calibrated every time the board starts
// or the values can be set by hand once, after entering calibration mode.
if (calibrateAccelerometerAndGyroOnStart && !calibrationModeEnabled) {
calibrateAccelerometerAndGyro();
if (calibrationModeEnabled) {
calibrateSensors();
while (1)
// Flash three times to indicate setup is over
for (i = 0; i < 3; i++) {
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
digitalWrite(LED_BUILTIN, LOW);
delay(100);
currentTime = millis();
String cardinal;
if (myIMU.accelerationAvailable() && myIMU.gyroscopeAvailable()) {
myIMU.readAcceleration(ax, ay, az);
myIMU.readGyroscope(gx, gy, gz);
// Remove accelerometer bias
ax -= accel_zerog[0];
ay -= accel_zerog[1];
az -= accel_zerog[2];
// Remove gyro bias
gx -= gyro_zerorate[0];
gy -= gyro_zerorate[1];
gz -= gyro_zerorate[2];
previousTime = currentTime; // Previous time is stored before the actual time read
currentTime = millis(); // Current time actual time read
elapsedTime = (currentTime - previousTime) / 1000; // Divide by 1000 to get seconds
// Currently the raw values are in degrees per second, deg/s, so we need to multiply by seconds (s) to get the angle in degrees
gyroPitch += gx * elapsedTime; // deg/s * s = deg
gyroRoll += gy * elapsedTime;
gyroYaw += gz * elapsedTime;
// ----- Compensate pitch and roll for gyro yaw
gyroPitch += gyroRoll * sin(gz * elapsedTime * DEG_TO_RAD); // Transfer the roll angle to the pitch angle if the Z-axis has yawed
gyroRoll += gyroPitch * sin(gz * elapsedTime * DEG_TO_RAD); // Transfer the pitch angle to the roll angle if the Z-axis has yawed
// ----- Accelerometer angle calculations
accTotalVector = sqrt((ax * ax) + (ay * ay) + (az * az)); // Calculate the total (3D) vector
accPitch = -asin((float)ay / accTotalVector) * RAD_TO_DEG; //Calculate the pitch angle. The sign is negative because, as the pitch increases, the gravity vector increases on the accelerometer -Y axis.
accRoll = asin((float)ax / accTotalVector) * RAD_TO_DEG; //Calculate the roll angle
gyroPitch = gyroPitch * 0.9 + accPitch * 0.1; //Correct the drift of the gyro pitch angle with the accelerometer pitch angle
gyroRoll = gyroRoll * 0.9 + accRoll * 0.1; //Correct the drift of the gyro roll angle with the accelerometer roll angle
gyroPitchOutput = gyroPitchOutput * 0.70 + gyroPitch * 0.3; //Take 70% of the output pitch value and 30% of the raw pitch value
gyroRollOutput = gyroRollOutput * 0.70 + gyroRoll * 0.3; //Take 70% of the output roll value and 30% of the raw roll value
if (myIMU.magneticFieldAvailable()) {
myIMU.readMagneticField(mx, my, mz);
float mag_data[] = { mx, my, mz };
// Apply hard iron offsets
for (int i = 0; i < 3; i++) {
mag_data[i] -= mag_hardiron[i];
// Apply soft iron scaling
mag_data[i] *= mag_softiron[i];
mx = mag_data[0];
my = mag_data[1];
mz = mag_data[2];
magRoll = gyroRollOutput * DEG_TO_RAD;
magPitch = gyroPitchOutput * DEG_TO_RAD;
// ----- Apply the standard tilt formulas
//Original formula
//magXHor = mx * cos(magPitch) + my * sin(magRoll) * sin(magPitch) + mz * cos(magRoll) * sin(magPitch);
//magYHor = my * cos(magRoll) + mz * sin(magRoll);
magXHor = mx * cos(magPitch) - my * sin(magRoll) * sin(magPitch) + mz * cos(magRoll) * sin(magPitch);
// ----- Dampen any data fluctuations
magXDampened = magXDampened * 0.7 + magXHor * 0.3;
magYDampened = magYDampened * 0.7 + magYHor * 0.3;
float headingRadians;
if (useBoardMagnetometerReferentialToPointAtHeading) {
// Use this if you want to use the board referential's X axis to point to the measured heading.
headingRadians = atan2(-magYDampened, magXDampened);
// Use this if you want to use the side of the board opposite to the USB port to point to the measured heading.
headingRadians = atan2(magXDampened, magYDampened);
float headingDegrees = headingRadians * RAD_TO_DEG;
headingDegrees += geoDeclinationAngle; // Geographic North
if (headingDegrees >= 360.0) {
headingDegrees -= 360.0;
if (headingDegrees < 0.0) {
headingDegrees += 360.0;
if (headingDegrees > 348.75 || headingDegrees < 11.25) {
cardinal = " N";
} else if (headingDegrees > 11.25 && headingDegrees < 33.75) {
cardinal = " NNE";
} else if (headingDegrees > 33.75 && headingDegrees < 56.25) {
cardinal = " NE";
} else if (headingDegrees > 56.25 && headingDegrees < 78.75) {
cardinal = " ENE";
} else if (headingDegrees > 78.75 && headingDegrees < 101.25) {
cardinal = " E";
} else if (headingDegrees > 101.25 && headingDegrees < 123.75) {
cardinal = " ESE";
} else if (headingDegrees > 123.75 && headingDegrees < 146.25) {
cardinal = " SE";
} else if (headingDegrees > 146.25 && headingDegrees < 168.75) {
cardinal = " SSE";
} else if (headingDegrees > 168.75 && headingDegrees < 191.25) {
cardinal = " S";
} else if (headingDegrees > 191.25 && headingDegrees < 213.75) {
cardinal = " SSW";
} else if (headingDegrees > 213.75 && headingDegrees < 236.25) {
cardinal = " SW";
} else if (headingDegrees > 236.25 && headingDegrees < 258.75) {
cardinal = " WSW";
} else if (headingDegrees > 258.75 && headingDegrees < 281.25) {
cardinal = " W";
} else if (headingDegrees > 281.25 && headingDegrees < 303.75) {
cardinal = " WNW";
} else if (headingDegrees > 303.75 && headingDegrees < 326.25) {
cardinal = " NW";
} else if (headingDegrees > 326.25 && headingDegrees < 348.75) {
cardinal = " NNW";
//The magnetic pitch and roll are flipped
Serial.print("P R: ");
Serial.print(magPitch * RAD_TO_DEG);
Serial.print(" ");
Serial.print(magRoll * RAD_TO_DEG);
Serial.print(" Heading: ");
Serial.print(headingDegrees, 0);
Serial.println(cardinal);
void calibrateSensors() {
Serial.println("");
Serial.println("");
Serial.println("Tilt Compensated Compass sensors calibration starting");
calibrateMagnetometer();
Serial.println("");
Serial.println("");
Serial.println("Calibration finished");
void calibrateAccelerometerAndGyro() {
int i = 0;
// Remove any existing calibrations
accel_zerog[i] = 0;
gyro_zerorate[i] = 0;
Serial.println("");
Serial.println("");
Serial.println("Accelerometer and Gyroscope Calibration Starting");
Serial.println(F("Place board on a flat, stable surface!"));
Serial.print(F("Calibration starting in 3..."));
Serial.print("2...");
Serial.print("1...");
Serial.println("Now.");
i = 0;
while (i < numberOfAccelerometerAndGyroCalibrationCycles) {
accel_zerog[0] += ax;
accel_zerog[1] += ay;
accel_zerog[2] += az;
gyro_zerorate[0] += gx;
gyro_zerorate[1] += gy;
gyro_zerorate[2] += gz;
if (debugEnabled && i % 10 == 0) {
Serial.print("Progress: ");
Serial.print((100.0 * i) / numberOfAccelerometerAndGyroCalibrationCycles, 0);
Serial.println("%");
analogWrite(LED_BUILTIN, map(i, 0, numberOfAccelerometerAndGyroCalibrationCycles, 255, 0));
i++;
analogWrite(LED_BUILTIN, -1); // Disable PWM
accel_zerog[0] /= numberOfAccelerometerAndGyroCalibrationCycles;
accel_zerog[1] /= numberOfAccelerometerAndGyroCalibrationCycles;
accel_zerog[2] /= numberOfAccelerometerAndGyroCalibrationCycles;
accel_zerog[2] -= 1.0; // Removes gravity
gyro_zerorate[0] /= numberOfAccelerometerAndGyroCalibrationCycles;
gyro_zerorate[1] /= numberOfAccelerometerAndGyroCalibrationCycles;
gyro_zerorate[2] /= numberOfAccelerometerAndGyroCalibrationCycles;
if (debugEnabled || calibrationModeEnabled) {
Serial.println("");
Serial.println("");
Serial.println("Accelerometer and Gyroscope Calibration Results");
Serial.println("");
Serial.print("accel_zerog = [");
Serial.print(accel_zerog[0], 4);
Serial.print(", ");
Serial.print(accel_zerog[1], 4);
Serial.print(", ");
Serial.print(accel_zerog[2], 4);
Serial.println(" ]");
Serial.println("");
Serial.print("gyro_zerorate = [");
Serial.print(gyro_zerorate[0], 4);
Serial.print(", ");
Serial.print(gyro_zerorate[1], 4);
Serial.print(", ");
Serial.print(gyro_zerorate[2], 4);
delay(4000);
void calibrateMagnetometer() {
int i = 0;
float minmx = 32767;
float maxmx = -32767;
float minmy = 32767;
float maxmy = -32767;
float minmz = 32767;
float maxmz = -32767;
float mx, my, mz;
float chord_x, chord_y, chord_z; // Used for calculating scale factors
float chord_average;
mag_hardiron[i] = 0;
mag_softiron[i] = 0;
Serial.println("");
Serial.println("");
Serial.println("Magnetometer Calibration Started");
Serial.println(F("Move the board around to calibrate."));
Serial.print(F("Calibration starting in "));
for (int i = 5; i > 0; i--) {
Serial.print(i);
Serial.print("...");
i = 0;
while (i < numberOfMagnetometerCalibrationCycles) {
minmx = min(mx, minmx);
minmy = min(my, minmy);
minmz = min(mz, minmz);
maxmx = max(mx, maxmx);
maxmy = max(my, maxmy);
maxmz = max(mz, maxmz);
if (i % 100 == 0) {
Serial.print((100.0 * i) / numberOfMagnetometerCalibrationCycles, 0);
i++;
// ----- Calculate hard-iron offsets
mag_hardiron[0] = (maxmx + minmx) / 2;
mag_hardiron[1] = (maxmy + minmy) / 2;
mag_hardiron[2] = (maxmz + minmz) / 2;
// ----- Calculate soft-iron scale factors
chord_x = ((float)(maxmx - minmx)) / 2; // Get average max chord length in counts
chord_y = ((float)(maxmy - minmy)) / 2;
chord_z = ((float)(maxmz - minmz)) / 2;
chord_average = (chord_x + chord_y + chord_z) / 3; // Calculate average chord length
mag_softiron[0] = chord_average / chord_x; // Calculate X scale factor
mag_softiron[1] = chord_average / chord_y; // Calculate Y scale factor
mag_softiron[2] = chord_average / chord_z;
Serial.println("");
Serial.println("");
Serial.println("Magnetometer Calibration Results");
Serial.println("");
Serial.print("mag_hardiron = [");
Serial.print(mag_hardiron[0], 4);
Serial.print(", ");
Serial.print(mag_hardiron[1], 4);
Serial.print(", ");
Serial.print(mag_hardiron[2], 4);
Serial.println("");
Serial.print("mag_softiron = [");
Serial.print(mag_softiron[0], 4);
Serial.print(", ");
Serial.print(mag_softiron[1], 4);
Serial.print(", ");
Serial.print(mag_softiron[2], 4);
