barcode scanner and keypad
Hi
I beginner for Arduino i study with google and youtube and
I follow this example of barcode scanner
with my Arduino Uno and show it in 162 lcd LiquidCrystal
then I want to input value from key pad 4
4
to to show input in second line then I write code
#include <Keypad.h>
#include <hid.h>                           //Add to Oleg Mazurov code to Bar Code Scanner
#include <hiduniversal.h>                  //Add to Oleg Mazurov code to Bar Code Scanner
#include <usbhub.h>
#include <avr/pgmspace.h>
//#include <avrpins.h>                     //I disable this line because it is already included with Usb.h
//#include <max3421e.h>                     // I disable this line because it is already included with Usb.h
//#include <usbhost.h>                      // I disable this line because it is already included with Usb.h
//#include <usb_ch9.h>                      // I disable this line because it is already included with Usb.h
#include <Usb.h>
#include <usbhub.h>
//#include <address.h>                      // I disable this line because it is already included with Usb.h
#include <hidboot.h>
#include <Wire.h>
//#include <printhex.h>                      // I disable this line because it is already included with Usb.h
//#include <message.h>                        // I disable this line because it is already included with Usb.h
//#include <hexdump.h>                        // I disable this line because it is already included with Usb.h
//#include <parsetools.h>                    // I disable this line because it is already included with Usb.h
#define DISPLAY_WIDTH 16
// initialize the LCD library with the numbers of the interface pins
LiquidCrystal_I2C lcd(0x27, 16, 2);
const byte ROWS = 4; // Four rows
const byte COLS = 4; //  columns
// Define the Keymap
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = { 9,8,7,6 };
byte colPins[COLS] = { 5,4,3,2, };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
USB     Usb;
USBHub     Hub(&Usb);                                          //I enable this line
HIDUniversal      Hid(&Usb);                                  //Add this line so that the barcode scanner will be recognized, I use "Hid" below
HIDBoot<HID_PROTOCOL_KEYBOARD>    Keyboard(&Usb);
class KbdRptParser : public KeyboardReportParser
        void PrintKey(uint8_t mod, uint8_t key);             // Add this line to print character in ASCII
protected:
	virtual void OnKeyDown	(uint8_t mod, uint8_t key);
	virtual void OnKeyPressed(uint8_t key);
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
    uint8_t c = OemToAscii(mod, key);
    if (c)
        OnKeyPressed(c);
/* what to do when symbol arrives */
void KbdRptParser::OnKeyPressed(uint8_t key)
static uint32_t next_time = 0;      //watchdog
static uint8_t current_cursor = 0;  //tracks current cursor position
    if( millis() > next_time ) {
      lcd.clear();
      current_cursor = 0;
      delay( 5 );  //LCD-specific
      lcd.setCursor( 0,0 );
    }//if( millis() > next_time ...
    next_time = millis() + 200;  //reset watchdog
    //if( current_cursor++ == ( DISPLAY_WIDTH + 1 )) {  //switch to second line if cursor outside the screen I disable this to show input from keypad
      //lcd.setCursor( 0,1 );
    Serial.print( (char)key );      //Add char to print correct number in ASCII
    lcd.print( (char)key );          //Add char to print correct number in ASCII
KbdRptParser Prs;
    Serial.begin( 115200 );
    keypad.addEventListener(keypadEvent);
    lcd.begin();
    lcd.setCursor(0, 0);
    if (Usb.Init() == -1) {
        Serial.println("OSC did not start.");
    delay( 200 );
    Hid.SetReportParser(0, (HIDReportParser*)&Prs);        //Here I change  "Keyboard" for "Hid"
    // set up the LCD's number of columns and rows:
    lcd.print("Ready");
    delay( 200 );
  Usb.Task();
  keypad.getKey();
void keypadEvent(KeypadEvent eKey){
    lcd.setCursor(0,1);
    Serial.print(eKey);
    lcd.print(eKey);
but the output that show in lcd screen in line 2 is A
and i don't know where is come from
and i can't press the keypad to show too
Is there any things i missed
pleas help me
i try every way i can but it's not work
ps. sorry for my weak Eng gramma :cry:
  Usb.Task();
  keypad.getKey();
All you appear to be doing is to read a character from the keypad and doing nothing with it.
Try
  Usb.Task();
  char myChar = keypad.getKey();
  lcd.print(myChar);
Thanks a lot UKHeliBob
but when i try with your suggestion and i put
  Usb.Task();
  lcd.print(myChar);
  Serial.print(myChar);
i run in Serial monitor and
the result is same
'A' from no where and with infinite space
I want to know where i set it to print 'A'
I run your suggestion with example keypad code
 #include <Keypad.h>
#include <Wire.h>
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte colPins[COLS] = { 5,4,3,2 };
void setup(){
   //keypad.addEventListener(keypadEvent);
   lcd.begin();
void loop(){
  lcd.print(myChar);
and result is same infinite space
i try ma code with example keypad
#include <Keypad.h>
#include <Wire.h>
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
void setup(){
   lcd.begin();
void loop(){
  keypad.getKey();
  lcd.print(eKey);
it's work keypad can use but when i use it in code as i ask in topic
it's not work :cry:
now I finding some solution from your suggestion thanks for helping me , i'll try
really thanks a lot for reply me
