basic power input questions
Hello,
2 quick questions :
  1. If using a 12v battery, does it make any difference at all using the round 'centre-positive' jack input, or the Vin and ground pins ?
  2. Will using an unregulated 12v lead acid battery, connected to the input power jack on a UNO be safe or not ?
Many Thanks
Twogan
If I look at the schematic - http://arduino.cc/en/uploads/Main/arduino-uno-schematic.pdf - the only difference is a diode (check the upper right part )
So as far as I understand it should just work.
Either will work, but using the jack is better for 2 reasons:
  1. The diode will protect the Arduino if you accidentally connect the battery the wrong way round;
  2. The voltage regulator will dissipate a little less power (that power will be dissipated in the diode instead).
3 reasons - much less likely to accidentally plug the jack into the wrong socket - whereas with the Vin header you could accidentally short the battery to ground by putting the wire in the wrong hole.
That would blow your fuse - you do have a fuse don't you? Large lead-acid batteries can source perhaps 1000A if shorted, a fuse is not a luxury.
The 4 reasons Amongst the reasons (nobody expects the Spanish Inquisition etc.) for using the barrel jack are the above 3, and the fact that a loose pin with +12v on it may short against something whereas the +12v connection in the barrel jack is shrouded.
And a fanatical devotion to the Pope
AND
it is just so dam convenient.
