I’m sure this will be easy for you all but I can’t figure why this doesn’t work. My first While loop which is meant to simply light up separately in sequence 7 LED’s.
The first Led lights up, the second for a split second, then just reverts to the first pin again.
Any thoughts?
The above statements, in fact, stand as:
while(Pin < 8)
Which means that the MCU will wait as long as the value of "Pin variable" remains less than 8.
Once you get the while() working, your output won’t look like it’s flashing, because there’s no interval after setting the pin low.
Except for an empty or single line command, you don’t need the curly braces.
Thanks, that did the trick!
Thanks!!
Some programmers say that putting the sub-ordinate clause within pair of braces is a part of literate programming.
I suspect that that is a personal preference.
{ braces }
[ brackets ]
( parentheses )
since we're being whatever.
I've seen "round brackets" for parentheses, and similar.
Now I will make a martini. It will have gin in it. ![]()
a7
To be precise, you don't need brackets if you have only one statement.
This statement can be written on multiple lines, it does not matter at all.
the curly braces create a compound statement, grouping everything together into one statement and this fitting the expectations of the compiler to get only one statement after the while (condition)
it's OK to have only one statement in a compound statement, and in case you add stuff later to do within the while() loop, having already the brackets helps avoid coding mistakes. that's why some companies recommend always having the compound statement form.
yeah - most languages do have specific names for those
{ accolades }
[ crochets ]
( parenthèses )
< chevrons > (also known as anti-lambda)
but you have others (not used in C++)
do they have names?
➜ Lenticular Bracket, Double Angle Bracket, Tortoise Shell Bracket... so I think that's also why the other have the xxx bracket alternate name
The while loop works, but you should use a for loop here...
for (int i=0; i<8; i++){
pinMode(i, OUTPUT);
thank you
Or if you have a less regular set of pins you can use an array:
int outPins[] = {2,3,4,6,8,10,13,A1,A5};
for (auto pin : outPins){
pinMode(pin,OUTPUT);
