Hello everyone,
I am looking for a system to control a lamp bedside wireless dmx.
Here are the different things I have to put up:
1 - Put a 230v lamp on a mini battery
2 - controlling the intensity of the lamp with arduino dmx HF (the card is also on battery)
You can think about it? I really need help for this project as part of a theater that will play in early April.
What do I need to do this? (modules. ..)
Thank you for your help.
Person has no idea? If we put aside the lamp is replaced by an LED, you have a solution? An arduino card + XBee Module enough?
Regarding the lamp, do you think a battery and a 12v/220v converter work?
Does anyone have an idea to write the program to graduate with a lamp or LED arduino in hf?
Assuming the lamp is 220vac and you want to control the intensity then as such you can simply use a traic circuitry, if you want to use a battery then you should use a bulb that is DC drivable so that you do not need a inverter to convert the AC to DC and vice versa.
You have to write your code and we can assist you for that ,its purely voluntary at our part.
