Hello everybody. First time posting on this forum and new Arduino user as well. I have found an amazing amount of knowledge on this forum related to my project. However, I am experiencing an issue with my project that I can't quite figure out. My project is this:
I have a mini fridge that I have converted into a larger chamber that I wish to control the inside temperature with an Arduino. I also wish to log the temperature in a database on my LAN. The mini fridge has a start up amperage of 6.3A and running amps of 1.5. I have attached my diagram that I used in Fritzing. I am also new to Fritzing and could not find the LCD or the SSR that I am using. The parts that I am using are:
Arduino Uno with ethernet shield
Sainsmart 4-Channel Solid State Relay (link)
2x10k resistors
4.7k resistor
Dallas waterproof temp sensor
Sainsmart 20x4 lcd (link)
mini - fridge
heat element (link)
Everything works great when no load (fridge or heat element is not plugged in) is hooked up to the SSR. However, when I hook up the loads and everything is working fine, as soon as the fridge turns off my arduino freezes. It's only when the fridge shuts OFF that I have the problem. Sometimes I will get random crazy characters on the screen. Other times it will just be unresponsive.
I have tried very hard to research this problem on these forums and elsewhere to no avail. Some suggested a diode on the SSR and others a dedicated 5v power supply for the SSR. I'm unsure how to fix this problem. I don't think it is a code problem as the Arduino seems to be unresponsive only when load is attached but I will attach it anyways. I have tried moving the SSR away from the arduino as I heard on this forum that EMI could be an issue but that still doesn't fix the problem.
#include <OneWire.h>
#include <Wire.h>
#include <SPI.h>
#include <DallasTemperature.h>
#include <Ethernet.h>
#include <Time.h>
//#include <rtc_clock.h>
#define BACKLIGHT_PIN 13
#define HEAT 6
#define COOL 7
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
const int increaseButtonPin = 3;
const int decreaseButtonPin = 5;
const float differential = 1;
float currentTemp, celsius;
float setPoint = 60;
int incButtonPushCounter = 0;
int decButtonPushCounter = 0;
int increaseState = 0;
int decreaseState = 0;
int lastIncButtonState = 0;
int lastDecButtonState = 0;
int WindowSize = 2000;
static bool buttonIncPressedBefore = false;
static bool buttonDecPressedBefore = false;
int buttonIncTime = 0;
int buttonDecTime = 0;
// Ethernet Setup Stuff...
byte mac[] = {
0xB0, 0xDF, 0x3A, 0x84, 0xDB, 0x9C };
//I made one up here it should be
//listed on your ethernet shield box
//EthernetServer server(80); // place your server IP address here
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
IPAddress ip(192,168,1,18);
char state = 'I';
byte serverName[] = {
192, 168, 1, 17}; // Database server IP
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
// IC Default 9 bit. If you have troubles consider upping it 12. Ups the delay giving the IC more time to process the temperature measurement
pinMode(BACKLIGHT_PIN, OUTPUT);
digitalWrite(BACKLIGHT_PIN,HIGH);
lcd.begin(20,4);
pinMode(HEAT,OUTPUT);
pinMode(COOL,OUTPUT);
pinMode(increaseButtonPin, INPUT);
pinMode(decreaseButtonPin, INPUT);
digitalWrite(HEAT,HIGH);
digitalWrite(COOL,HIGH);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
//Serial.print("server is at ");
//Serial.println(Ethernet.localIP());
void loop(void)
increaseState = digitalRead(increaseButtonPin);
decreaseState = digitalRead(decreaseButtonPin);
lcd.home();
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
sensors.requestTemperatures(); // Send the command to get temperatures
celsius = sensors.getTempCByIndex(0);
currentTemp = 1.8*celsius + 32;
// Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
lcd.print("Current Temp: ");
lcd.print(currentTemp);
lcd.setCursor(0,1);
lcd.print("Set Point: ");
lcd.print(setPoint);
state = checkTemp(currentTemp, setPoint);
if(abs(millis()-buttonIncTime)>20){
if(increaseState == 0){
buttonIncPressedBefore = true;
setPoint = setPoint + 1;
buttonIncTime = millis();
//lcd.print(setPoint);
if(abs(millis()-buttonDecTime)>20){
if(decreaseState == 1){
buttonDecPressedBefore = true;
setPoint = setPoint - 1;
buttonDecTime = millis();
// if(buttonDecPressedBefore && abs(millis()-buttonDecTime)>100){
// setPoint = setPoint - 1;
// buttonDecPressedBefore = false;
// if(buttonIncPressedBefore && abs(millis()-buttonIncTime)>100){
// setPoint = setPoint + 1;
// buttonIncPressedBefore = false;
// Serial.print("Millis=");
// Serial.println(millis());
// Serial.print("buttonIncTime=");
// Serial.println(buttonIncTime);
// Serial.print("Diff");
// Serial.println(abs(millis()-buttonIncTime));
// Serial.print("Temp = ");
// Serial.println(currentTemp);
Serial.print("IncreaseState = ");
Serial.println(increaseState);
Serial.print("DecreaseState = ");
Serial.println(decreaseState);
if(state == 'H')
lcd.setCursor(0,3);
lcd.print("Heating");
if(state == 'C')
lcd.setCursor(0,3);
lcd.print("Cooling");
if(state == 'I')
lcd.setCursor(0,3);
lcd.print(" ");
lcd.setCursor(0,3);
lcd.print("Idle");
if(second() == 59)
lcd.setCursor(10,3);
lcd.print("Data Sent");
write2DB();
lcd.print(" ");
decreaseState = lastDecButtonState;
increaseState = lastIncButtonState;
char checkTemp(float currentTemp, float setPoint){
float currentDiff = abs(currentTemp-setPoint);
if((currentTemp < setPoint) && (currentDiff > differential) && second() == 59){
digitalWrite(HEAT,LOW);
state = 'H';
if((currentTemp > setPoint) && (currentDiff > differential) && second() == 59){
digitalWrite(COOL,LOW);
state = 'C';
// If currentTemp is within +/- differential then shut off
if((currentTemp > setPoint - differential) && (currentTemp < setPoint + differential)){
state = 'I';
return state;
void write2DB(){
client.connect(serverName, 80);
// Make a HTTP request: Sends information to "data.php" which lives on the RPi.
client.print("GET http://192.168.1.17/tempControl/data.php?"); //place your server address here
Serial.print("Sent Temp: "); //
client.print("Temp=");
client.print(currentTemp); //
client.print("&&");
client.print("SetPoint=");
client.print(setPoint);
client.println(" HTTP/1.1");
client.println("Host: http://192.168.1.17");
client.println( "Content-Type: application/x-www-form-urlencoded" );
client.println( "Connection: close" );
client.println();
client.println();
client.stop();
//delay(300);
Thank you very much for your help.
