Beginner help with Motor and Encoder library
Hi I am very new to ardunio and trying to get my geared motor to work.
I am using the following code:
#include <Encoder.h>
Encoder myEnc(14,12);
int E1 = 4;
int M1 = 5;
  delay(800);
  startMotor();
void startMotor() {
  int potValue=700;
  int mappedVal = map(potValue-512,0,512,0,255);
  analogWrite(E1, mappedVal);
  digitalWrite(E1,HIGH);
  analogWrite(M1, mappedVal);
and I am getting the following output in the serial monitor
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v00043b70
~ld
motor: CHIHAI GM4632-370 DC 12V 30RPM High torque Turbo Encoder Motor Worm Geared Motor Reducer Motor Sale - Banggood UK-arrival notice-arrival notice
driver: https://www.amazon.co.uk/gp/product/B07F9LH4PJ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
any point in the right direction would be helpful!
board: https://www.amazon.co.uk/gp/product/B0754W6Z2F/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
It doesn't look as if you posted all your code.
Apologies I missed the E1 and M1 variables, I've updated the code above
Hi, can't see any loop function in your code.
The stack trace means your sketch crashed the CPU.
It's there, I was just removing any code that would seem unnecessary, I've added it back in to the code above.
It seems to only crash on this line
What would that mean? Something wrong with the wiring on those pins?
One problem, declaration in setup ().
Ok so move this line into setup?
I'll give it a go now
Nooooo... When did I say to do that?
Okay, which declaration needs to go into the setup? Sorry I'm relatively new to this
ahhh the void bit!
Opposite. It needs to be removed from setup. Do you know what a declaration is?
Just call the function
So move the function that calls the startMotor() into the loop() instead?
Maybe ensure it only gets called once
No not even close
Can you provide an example?
Sure, any C program that calls a function. You were so close, just remove the void key word. That is what makes it a declaration.
I think that was a typo in my code, I didn't actually have the void bit when calling that function. I've updated the code above.
--> I've hit the max number of replies for a new user?! How strange <--
I've redacted the code to help reduce the noise in the ticket.
I see you edited the original post to change the line in question. Please never do that, it makes nonsense of the replies.
Also, are you telling me that the code you posted is not the same as the code that produces the error? That would be very misleading. As would “ redacting the code". Please spend some time reading the forum rules.
Your post privileges will be granted in 24 hours.
