Beginner-level Arduino programming
I am currently working on a project about horizontal control of a single-axis rotating drone.
The drone’s flight controller is a SpeedyBee F405 All-in-One flight controller. It is assembled together with two motors mounted on one axis. The axis is already fixed. That means the drone has two motors positioned 180° apart and can only rotate around the x-axis.
PID control is required to adjust the wing position to maintain a horizontal level position.
Additionally, wireless data transmission between the computer and the flight controller needs to be implemented.
The hardware also includes an ESP8266 module to enable wireless communication functionality.
My question is: What specific functions can be implemented using Arduino programming in this setup? Could you explain in detail? I am a complete beginner.
Thank you very much for your guidance.
Unfortunately, what you describe is simply not a beginner-level project. You're going to need to crawl before you run.
You mention ESP32, but it might be better to start with Arduino documentation...
https://docs.arduino.cc/language-reference/
... Arduino programming exercises...
https://docs.arduino.cc/built-in-examples/
... and some Arduino tutorials.
I have deleted your other cross-post @nathantal.
Cross-posting is against the Arduino Forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
