Beginner question: first project with LEDs isn't working
I'm trying to follow this tutorial:
My board is ESP32 devkit v1 and I'm using arduino IDE.
I have 2 issues: the red led doesn't work (I've tested the red led and it is working), the green led
works but the buttons don't turn it on and off, it switches on when I plug in the board.
This is the board:
This is the complete code that I wrote:
// Load Wi-Fi library
#include <WiFi.h>
// Network credentials Here
const char* ssid     = "ESP32-Network";
const char* password = "Esp32-Password";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
//variables to store the current LED states
String statePin16 = "off";
String statePin17 = "off";
//Output variable to GPIO pins
const int ledPin16 = 16;
const int ledPin17 = 17;
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds
const long timeoutTime = 2000;
  pinMode(ledPin16, OUTPUT);      // set the LED pin mode
  digitalWrite(ledPin16, 0);      // turn LED off by default
  pinMode(ledPin17, OUTPUT);      // set the LED pin mode
  digitalWrite(ledPin17, 0);      // turn LED off by default
  WiFi.softAP(ssid,password);
  // Print IP address and start web server
  Serial.println("");
  Serial.println("IP address: ");
  Serial.println(WiFi.softAPIP());
  server.begin();
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    previousTime = currentTime;
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected() && currentTime - previousTime <= timeoutTime) {
      // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the GPIOs on and off
            if (header.indexOf("GET /16/on") >= 0) {
              statePin16 = "on";
              digitalWrite(ledPin16, HIGH);               // turns the LED on
            } else if (header.indexOf("GET /16/off") >= 0) {
              statePin16 = "off";
              digitalWrite(ledPin16, LOW);                //turns the LED off
            if (header.indexOf("GET /17/on") >= 0) {
              statePin17 = "on";
              digitalWrite(ledPin17, HIGH);               // turns the LED on
            } else if (header.indexOf("GET /17/off") >= 0) {
              statePin17 = "off";
              digitalWrite(ledPin17, LOW);                //turns the LED off
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            client.println("<style>html { font-family: monospace; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: yellowgreen; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 32px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: gray;}</style></head>");
            client.println("<body><h1>ESP32 Web Server</h1>");
            client.println("<p>Control LED State</p>");
            if (statePin16 == "off") {
              client.println("<p><a href=\"/16/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/16/off\"><button class=\"button button2\">OFF</button></a></p>");
            if (statePin17 == "off") {
              client.println("<p><a href=\"/17/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/17/off\"><button class=\"button button2\">OFF</button></a></p>");
            client.println("</body></html>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
Any help is appreciated.
Verify your wiring. LEDs have polarity.
You appear to have connected the LEDs to the wrong pins.
GND seems to be correct.
But the LEDs are connected to GPIO 12 & 14 as far as i can tell
Since GPIOs 16 & 17 are on the other side of the board and a little tricky to get to when it is plugged into the breadboard like this, you could consider correcting the code to use the pins you connect to (it may look strange, but that would mean
const int ledPin16 = 12;
const int ledPin17 = 14;
or move the board 1 row to the side and use the exposed GND pin on the other side.
not that GPIO 16 & 17 are marked RX2 & TX2
That solved it. Thanks!
Did the diagram of post #3 helped you?
Yes, very much.
4 posts were split to a new topic: Program not working after I changed LED circuit
