I am really new to Arduino. I have a projekt, which needs to be powerd 24/7, which uses a Mkr 1000 as its Mikrocontroler. What is the best way to power the Arduino? I heard, that batteries just last very little time and I am genuinely scared to plug it into an outlet, I dont wont to start a fire or something :). I guess using batteries and recharging them with solar panels would be an option, but I guess that that sort of project is a bit to advanced for me.
Is there a better way I am not aware of?
Thanks in advance
Daniel
The simple phone chargers that most phones use is a good starting point.
A lot depends on what else you are connecting to the board in the first place an those power requirements as the board does not supply much current.
Could you also review How to get the best out of this forum as it will help you find your way around.
Thanks for the reply and sorry for not giving you all the information you needed :).
I am just going to connect 3 Servos to the board and I will be using SG90 9g Mini Micro Servos, which run on 5V.
So can I just plug a Phonecharge that outputs 5V into a powerplug? I have read that you shouldn't supply the board with more than 3.3V (https://store.arduino.cc/arduino-mkr1000-wifi), but I guess that's only true for the vin pin?
The USB port on the board converts the 5 volts from the phone charger for you and is perfectly safe.
The servos on the other hand require more current than the board can supply so will need a seperate 5 volt feed and a common ground back to the Arduino as well.
Alright, thank you very much for your great Help! Have a nice Day
